There is another option.
I replace mine on '99 RX300. The original motor I think was FC-280PT-22125
I used FC-280SC-20150 which has a bit longer shaft, so I cut it using Dremel Cutter and it works fine.
Another door I replace the cap with brushes from FC-280PT-20150, it fit well and works.
Note: 20150 has a little bit less torque than the original 22125, but it seems enough to do the job.
The motor might works with other cars too.
For details I have posted in club lexus forums Door Lock Acutuators DIY ??? - Page 22 - Club Lexus Forums post #326
In my opinion it is easier to replace the motor than replacing the cap. But you must remove the collar from your old motor and put it in the new motor.
It's easy to do. The only hard part is opening the clam shell, and taking the whole assembly out of the door. But once you did it, its not that hard.
If anyone need the motor I still have some of both motor, just email me.
Good luck!
Good luck!
