Needed to clean my TB/intake, and, since there was some corrosion on my valve cover, I decided to pull it and have it blasted so I could paint it and make it look better. it now looks great..... but, what I didn't realize was the pvc system vents have trapped sand up in the baffles.
I should have searched mud first, because there are other posts warning not to blast it at all and to chemically clean it only... ughfff!!. too late for me to do it the smart way...
I've tried for several hours to flush things out with water, but it seems like there are too many twists and bends up there and I still feel loose grit up in there.
So.... do I need to add a new valve cover to my shopping list? or is there a way to break into the baffle to clean it? my initial thought would be to pry open the baffle or cut through the rivets and wash them out and tap a few bolt holes and use bolts fipg to put it back together.
I'm new to working on toyota engines, but I should have known better.... damn.
Any suggestions or advice on how to fix it?
