Hey guys,
First off, I apologize in advance if there is a thread about this (which I am sure there is) that I missed.
I have a 5/'75 FJ40 with original 2F.
It has been sitting up since 2010 under the barn. I have been working on bringing it back to life but am having issues with it cooling.
First things first, when we got it running, antifreeze looked good and levels were correct. I test drove it for about 10 min and stopped to check everything. The radiator started boiling over and the temp gauge wasn't registering (I know they suck anyway).
We pulled it back in the shop and pulled the thermostat assuming that it was stuck and not properly opening. It appeared fine but I replaced it with a new one I had on hand anyway. (I didn't have the ability to pop-test either of them)
I sealed her all back up hoping that would be an easy fix. Well next weekend when I got back to it to test again, the same thing happened.
So my next option was to drain the block and radiator and start attacking all of the gunk buildup I've read so much about.
To my surprise, the radiator drained flawlessly after I shoved a punch through a small gunk buildup in the drain pipe. The antifreeze looked pretty good for sitting so long.
The block was easier than I expected also. The plug was a b*tch to break loose, but after I got it open, it once again drained with no issue. This is where I expected to have the issue after the radiator drained.
So the main question is... Where do I go from here?
If I left any info out, let me know!
Thanks for the help in advance guys!
