For a US Spec 1993 FZJ80, a good place to tap the reverse light circuit is in the driver's side kick-panel.
I found no good photos or great description about where precisely to find this back-up light signal source in cab for reverse lights (my project) and backup cameras (many others asked). (Many words added here to aid search.)
Once I found the connector, it was easy to find the wire and connect it to my switch. I'm using a single pole double throw (SPDT) switch so my roof rack rear facing lights can be on with Reverse, off, or on (for camp setup or area light).
Photo one: Tip of screwdriver shows pin on male connector.
Photo two: closeup (I highlighted the pin in black). Wire out the back of the male connector is red with black stripe.
Photo three: This is the female side after pin removed. I added a black mark. In my hand is the modified pin.
Photo four: Close up of female side connector.
