Wow...Shotts was civil, had great input, and was generally pleasant to be around! Thanks for pointing that out and helping make the A-TRAC FAQ as accurate as possible.
Only because I'm hanging out in the Corvette Forums now.
Lockers are always better in off-camber situations. a-trac is better in a tight, narrow trails. There is a place for both when the time comes.
I love revving my hundy to 12,000 rpm and then dropping the hammer
Could a 98-99 rear 3rd member with factory locker be installed in a 00-02 model to have matching gears, a-trac and a rear locker?
If your axle was locked and you had ATRAC, wouldn't the ATRAC be applying the brake to the spinning, off-the-ground wheel and therefore be attempting to stop the whole (locked) axle? It seems like if you were locked at one end you'd want ATRAC disabled at that end.
Been covered in a number of threads. When axle locked A-trac would not see a difference between left and right wheel speed, so no need for it to brake a wheel.
To oversimplify 2000UZJ's fine write up, a-trac applies brake to the wheel or two going faster than the rest to make it go same speed as the others, with lockers they are going the same speed.
Hey, just a quick question... I'm thinking of potentially moving into a sequoia (family size) in a year or two. I'm just wondering if it has atrac, and also if it does, then does it work very similarly? Are there differences? Anyone here know, and perhaps those that have driven one offroad could chime in?
My goal wouldn't be to purchase more capable vehicle (obviously); and that being said, I don't really wheel mine too much, and when I do, it's extremely light, mostly FSR's and the odd spur off to the side that's a bit steeper, but that's it.
I didn't see any comments about potentially upgrading the software to a newer version of A-trac.. I wonder if that is possible?
It is really cool technology.
I have been told the best aftermarket lockers are superior to the OEM e-lockers, so probably better to buy after market then try to install OEM e-lockers.
I was recently playing around on some "moguls" and I wasn't very impressed with the ATRAC on my '02. I was in 4L, in Drive, CDL locked, and held a steady 1500 rpm or so. One of the rear tires was spinning freely for a good 5-seconds with no traction so I let up on the gas. Should I have stayed into it longer? I ended up backing up a bit to carry a bit more momentum and then I was able to roll right through the little "obstacle".
On my previous '07 FJ Cruiser, the ATRAC system was flawless. The ATRAC worked so well I never needed to lock the rear differential.
I understand that the newer ATRAC system uses dual sensors at each wheel for a more aggressive ATRAC intervention, but is there an updated software for the older LC's to improve ATRAC functions?
Maybe there's something wrong with my ATRAC.
Any help would be greatly appreciated.
