Hello again! I just posted a thread a couple of weeks ago about what to carry as spares on trips. The one thing that I wasnt sure about was if the fuel pump had ever been replaced. Well, This morning I was about 5 miles from home on the freeway and the truck started to lose power until it would barely run. I was lucky to be near an off ramp and coasted off of the freeway. Then it would start and run intermittently and stall.
I got it towed home and was checking to see if the fuel pump was getting power. I jumped the T connector on the left fender apron near the other diagnostic plugs per the FSM but no fuel pump noise. I removed the supply hose to the rail and no fuel pressure at all. I jumped the connector with the fuel hose removed and no fuel. I can hear a relay near the passenger side clicking when I jump the connector but no fuel. Does it sound like a fuel pump problem? I did get a check engine light when this happened and the codes are 5 and 6. I think they were triggered because the engine was in gear and running when it started cutting out?
