Registry 80 Series Registry (9 Viewers)
Hey guys, new member here. My name's Matt, I live in Snohomish county Washington. I had a 97 Land Cruiser but totalled it and now have a 97 LX450 with 240k on it. It's all stock besides the aftermarket head unit.
Since I bought it last October I've replaced
-plugs, wires, cap, rotor, distributor o-ring
-water pump, thermostat, fan clutch, radiator
- block engine coolant temp sensor
-drive belts
- replaced broken headlight/corner lamp car came with
- BF Goodrich all-terrain KO2's
- cleaned up the paint real good
Future plans relatively soon are
-rebuilding the knuckles
- OME 2.5" & 33'S
- bumpers, sliders, winch.
Future plans a little further out are v8 or 4bt swap and replacing the ripped leather seats
I've got a clogged drain hole I need to clear out this week that I just noticed after washing it and rain.
I bought the car as a daily driver so I don't have to beat up my GS300 that I'm swapping a 2jzgte into. I use the LX to get to mountains for snowboarding and shooting and would like to take it on trails once I lift it.
• 1997 Toyota Land Cruiser FZJ80 "Poverty Pack"
• Lee aka Tex68w
• Poverty Patty
• 212K, mostly rebuilt
• 2.5" OME, TJM T17 bumper, Warn M8000S, 285/75/16 BFG AT KO2, 70 Series 16x7" steel wheels, Alpine deck, Rockford Fosgate speakers, Slee Step Sliders, 4x4Labs rear bumper/carrier (coming soon).
1. 1993 FZJ80
2. Quinn
3. I refer to it as 'My Toyota'
4. 248k miles
5. Just had ARB grill guard and winch installed, other than that it's stock.
6. Every day vehicle plus off-road and camping
7. See attached photo
I'd like to do anything I can to keep this vehicle running another 10-20 years, I have no desire to drive anything else. I've owned it since it turned its 200k mile. Haven't done any work on it other than routine maintenance and repairing a couple minor oil leaks. Any advice from the +250k mileage crowd would be greatly appreciated.
My second stint here. Sold my 40th 3 years ago and just picked this one up two weeks ago. So stoked!
'97 locked and flareless, 225K with OME lift, non-winch ARB and 295/75 16 BFG A/T's. A long list of PM and baseline coming soon. Then, OEM JDM Aisin winch, OEM door weather guards, 285/75 16 Super Swamper ND and Mickey Thompson wheels.
1. 1992 LC - Tractor motor and bus trans
2. Mark
3. Not sure
4. 225k
5. Besides maintenace - ARB winch bumper, 15x8-19 with 33x10.5r15 BFG KO2, dish steering wheel, subs, auto start/alarm. Awaiting install/on the way: Smittybilt Winch, Powertrax rear locker, OME lift kit
6. Camping/wheeling/daily
wow that's super clean!!!
Hi All,
Thanks for having me. I just transitioned from an 06 Tundra to a 97 FZJ80 and this is my maiden post on MUD. I'm guessing this rig isn't new to some of you, but it's new to me. I had the good fortune of buying this from a master tech who was insane with his build. I'm still learning what some of these parts are. Needless to say, I can't answer tech specs about the build. However, I'm enjoying it and I'm guessing you'll enjoy reading about it.
1. 1997 FZJ80 Collector Edition (Picture at bottom)
2. Brian
3. Van De Cruiser or Cactus Cruiser (undecided)
4. 194,000
5. Mods (just a couple):
Front Suspension
  • Old man emu 850 J springs 3" lift
  • Slee Offroad front caster correction plates
  • Radflo 2.5" long travel remote res shocks 7/8 shafts
  • 2" drop bump stop pucks slee offroad
  • Iron man front adjustable heavy duty track bar
Rear Suspension
  • TJM 2.5" progressive rear springs
  • custom spring retainers
  • Iron Man adjustable heavy duty track bar
  • custom drop bump stop brackets 3.25"
  • custom rear shock mounts 1.50"
  • Icon shock skids
  • Metal Tech HD lower links with johnny joints
WHEELS and TIRES
  • 37x 1250 R 17 cooper sst MT tires
  • Walker Evans Beadlooks 17x 8.5 3.75 bs (5)
Front Axle
  • Nitro Gear chromoly 30 spline front axle shaft kit
  • APR knuckle studs
  • full front axle rebuild at 178K wheel bearings , front brake, seals etc
  • ARB air locker
  • 488 gears with full bearings at 178K
  • Slee offroad AVM manual locking hub kit (part time 2wd kit)
  • Slee Offroad steel braided extended brake lines
  • Slee Offroad front sway bar drop brackets
  • TAC double CV front driveshaft
  • Marks 4WD abs sensor relocate kit
Rear Axle
  • Nitro rear chromoly full float 30 spline axles shafts
  • ARB air locker
  • 488 gears
  • OEM rear brakes replaced 178K
  • Slee offroad rear steel braided brake line
  • Manafre rear brake proportion drop bracket
  • Rear drive shaft rebuild and tubed
Transfer Case
  • Marlin Crawler low range gears 3.116 to 1
  • Slee Offroad T case spool (part trim kit )
Engine OEM parts restoration at 178K
FULLY built cylinder head and every seal replaced with OEM parts
new OEM radiator and all rubber hoses
full trans service at 190K
ARMOR
  • front bumper Slee Offroad short bus
  • rear bumper 4x4 labs high clearance
  • white knuckle rock sliders
  • Iron pig center HD crossmember/ t case skid
  • sonoran steel spare tire carrier
  • smitty built H2O 8K syth winch
LIGHTS
  • rigid d2 duallys euro beams front
  • 16 led rock light pods under carriage
  • interior full led conversion
6. Daily driver and weekend warrior
1) 1994 fj80
2) Val Romero
3) Cruiser
4) 250,000mi
5)2.5in lift/30mm spacers up front,rancho shocks, toyo MT 33's on generic aluminum 17's,Tjm t17 front bumper, 4x4 labs rear bumper, lq4(Chevy ls 6.0) w/4l80e trans, custom exhaust, depo headlights, slimline roof rack/rrt
6) go wherever I want
1. 1996 FZJ80
2. Jason
3. Crusher
4. 250k
5. Weld on rock sliders
6. Truck is a weekend Toy. I've had it for 4 days. My woman surprised me with it on my Birthday on May 1st. I found it on Craigslist in February and she secretly bought it out from underneath me and hid it for months.
1. 1996 FZJ80
2. Jason
3. Crusher
4. 250k
Fun story. She's a keeper.
1. 1994 - FJ80
2. Lucas
3. Name of rig.....hmmm will need to work on that
4. 273,XXX miles
5. Right now in PM land trying to ensure its solid so I can start beating it up
6. How the truck is used....it functions mainly as vacuum to empty my bank account
Build Thread.....
1. 1992 FJ80
2. Katie Widener
3. Lurch
4. 252K Original miles
5. Factory diff lock, Kenwood stereo system, upgraded brakes all the way around, waiting for OME 2.5 lift and 33'' BFG KO2 tires next payday. Having custom front bumper with 2'' receiver built along with rock sliders and rear bumper. Getting ready for paint (flat black) as we speak. Just bought her 2 weeks ago.
6. Grocery getter, weekend warrior
1. 1996 FZJ 80
2. Tanner
3. None Yet
4. 115K
5. Completely Stock (May keep it this way too)
6. DD. I purchased this vehicle after years of debate of whether I wanted to keep my truck or get a 4runner or some other type of SUV. I have lusted over the 80's for quite some time now and as I was coming to peace with keeping my truck; my wife went on craigslist and said I think you need to see this one. I took it as a sign and haven't regretted it since. I can't wait to get this thing "Baselined" so I can go have some fun!!
Hey guys, I have been creeping on ih8mud for a while but never posted anything. You can see old pics of my 80 on my instagram @mlancewilliams. However, I will come on here more and post some pics of my pig-rig. I am excited to drop my Cruiser on here that I have had for 6 years. I have had a lot of help in transforming it into an 80 that I love. I hope you enjoy it.
1. 1997 FZJ80 LX450
2. Lance
3. Roffe'
4. 209,000
5. Mods...
  • Old man emu 2.5"
  • 295x70/17 Toyo MT
  • 07 Toyota FJ cruiser wheels
  • Super Charger installed at 208K
  • Birfs redone recently
  • Slee Offroad step sliders
  • Slee Offroad rear bumper
  • ARB front bull bar bumper
  • Prinsu roof rack
  • Complete color change (vinyl wrapped) in 2016 from dark green to the old toyota tan
6. Overlanding, moab outings, and weekend camping (Daily driver is S-line Audi A6... Other vehicles: 1998 LC 100 series, 1974 CJ-5)
1. 1996 FJ80
2. Jason
3. Irwin (Steve)
4. 263,XXX
5. 285s Discovererers, took off running boards, done a bunch of neglected maintenance, planning some bumpers with hitch receivers for a winch.
6. Currently my only vehicle.
1995 FJ80
Mark
No name yet
217,000mi.
Have had it 8 hrs put 100 miles on it to get home no issues, PO had a laundry list of things that have been done and after putting some miles on it, I believe no bull****. Needs some cosmetic work but all the mechanical stuff is great. Really needs seats recovered and some paint repair not sure what to do about that, newer paint clear coming off all over. Came with all kinds of spare stuff
Forgot to put up pic. And this is purely a toy. My DD is a Diesel Dodge for work. Not sure what the first post I did is all about. Let the spending begin....
