really like your wheels and considering buying that style for my LC16. where did you get them?Upgraded or downgraded my wheels depending on your taste.
thanks!you can get them all over, 4wheel parts, discount tire etc... Fuel Anza's 5x150 20mm offset
Anza, 18x9 with 5 on 150 Bolt Pattern - Gun Metal Matte
what kind of lift do you have on your truck and do you think a lift is needed to fit these wheels with 285-70 R18's BFG's?you can get them all over, 4wheel parts, discount tire etc... Fuel Anza's 5x150 20mm offset
I have the Ironman Cellfoam pro kit with Toyota coil spacers in the front... You would absolutely have to install a lift to run the Anza wheels and 285-70 R18's BFG's!what kind of lift do you have on your truck and do you think a lift is needed to fit these wheels with 285-70 R18's BFG's?
looks like your in Washington, @torfab can help you out with your setup...what kind of lift do you have on your truck and do you think a lift is needed to fit these wheels with 285-70 R18's BFG's?
indeed. spoke to Tor couple of days ago about my fzj80. he is great. definitely hitting him up on this. again, thanks for sharing your upgrades here. the knowledge is priceless!looks like your in Washington, @torfab can help you out with your setup...
Both the white @RockdogAdventures and silver @codyaustin5 are running TRD Rock Warriors IIRC.where did you get the wheels on the silver LC200?
when ya get the rig all dialed hit me up and let's do some wheelin!!!indeed. spoke to Tor couple of days ago about my fzj80. he is great. definitely hitting him up on this. again, thanks for sharing your upgrades here. the knowledge is priceless!
You bet.when ya get the rig all dialed hit me up and let's do some wheelin!!!
Thanks. I will check it out bBoth the white @RockdogAdventures and silver @codyaustin5 are running TRD Rock Warriors IIRC.
Did he write you?A little to heavy on the skinny pedal I guess
yep, 65mph in a 50mph He said he cut me a break and wrote it for 120 bucks!Did he write you?
Ah that sucks, if he cut you a break how fast he get you at, 75-80?yep, 65mph in a 50mph He said he cut me a break and wrote it for 120 bucks!
he said he got me at about 70mph...Ah that sucks, if he cut you a break how fast he get you at, 75-80?
after of courseBefore or after you hit your brakes?
