This is the cart I need to build for the house we just bought. My "shop" is in a walk out basement on the back side that is accessed by stairs and a steep sidewalk. Looks like I need to cut up the one I was almost finished building.My first aluminum project when I got my Miller 200DX tig/stick unit was the cart -
I designed it this way so can be moved on a flight of stairs and still fit through a 28" door opening if necessary . Cart only weighs in at 45lbs and have upgraded to a 150 size tank since this photo .
Be warned , using tig on body panels is going to require an aluminum backer or purge box to trap the argon , otherwise you'll introduce oxygen to the back side of the weld/panel . Using dc pulse is great on thin stuff , just watch out for heat building as a tig can warp panels just as easy as a mig , if not worse .
Sarge
Mind if I borrow some of your design?
