Vae Victus
Posting more than I know
- Thread starter
- #1,361
Also got the new tires on the powder coated steelies! Now I just need the frame back from PC.
ick, long-butt-weld
are the fenders made to go over the top of the current fender? if not get one of these
on one side is a hole punch, on the other it makes a step or flange in the metal. you cut the fender so it overlaps, punch holes on the other part then plug weld it on. The only downside (and it's one for this one) is you can see the work on the inside and it looks not-so-nice. On the outside, once you make the step, weld the holes then use fiberglass-reinforced filler in the space between - looks like nothing ever happened and is a permanent repair.
With that said....
Were it me, I'd cut and replace the pieces that need to be replaced. If you do the entire fender, you have an entire fender of heat distortion to cope with...
Northern Industrial Air Punch and Flange Tool | Air Punch Rivet Tools| Northern Tool + Equipment
air flange and punch tool.... they sell them at Harbor Freight as well. I bought mine before there was a HF - but it's quality is about the same and it has lasted quite well.
With that said, I'd do a vertical butt weld across that (cut just the damage off then have a much shorter weld)...
Do what's in Rainman's picture. Remove the whole fender and replace with new. This way, the only seams are the ones that look factory. This will yield the straightest fenders in the end.
I was very careful with each of my patches, but you can still find repairs. If I needed bigger patches, I'd have purchased panels and replaced the whole thing.
I am sure you have seen this already, but step-by-step pictures on CCOT website:
Body Panel Installation
Make sure to brace, brace, brace before cutting away old fender!
I know your pain. I have land cruiser parts in 4 different buildings at various locations.
Yup - garage, basement, and parents' garage here...
Garage, basement, and driveway here. Nothing is for free, this prime real estate cost me a complete kitchen remodel. Our new oven, errr range, cost more than my first cruiser and the tile cost as much as my paint job. A 10x10 would have been cheaper.
happy wife, happy life.... there are costs.
Goodness....just pushed through the whole thread....and loved every minute of it. Learned a ton. Hope I don't forget it all. Thanks for documenting.
If that had been my 40, I would have put on a trollhole carb, new tires, all new fluids, fixed the starter wiring, and driven the thing for a while.
Still adding up costs?
Whats your Daily driver? Just curious.
And geez....$189/month for a 10x10?! I'm in the wrong business.
What size tires? Why not black wall out on them? Makes for a cleaner, classic look, IMO.
