- Thread starter
- #41
Also, what brand is OEM? NGK? Denso? Forgot to ask in previous post. lol
Personally, I would feel better about a used OEM unit as opposed to a new aftermarket one, but the choice is yours. I stay away from aftermarket parts.Awesome! Thanks guys! What about a new one and not a reman'd one? Is it just longevity or will it not run as smooth and good?
What about a new one like this: Richporter Technology TY35 - Distributor | O'Reilly Auto Parts
Thats not going to be a toyota part and very pricey. If your not going to go with toyota try this 1991 Toyota Land Cruiser Distributors | Replacement 1991 Toyota Land Cruiser Distributors | 1991 Toyota Land Cruiser Ignition Distributor Assembly | 1991 Toyota Land Cruiser Aftermarket Engine Distributors At 1A Auto. Ive had one in my 91 for 3 years now with no issues
Depends on the system but most toyotas use a signal from the crank sensor (ckp) to the computer (PCM). This helps it determine when to ground coil or igniter and produce spark. If you are getting spark from the coil to the distributor chances are you have a bad distributor. Seen them test ok with a meter and still not work once installed. If you don't have spark from the coil it's probably a coil or igniter. Easiest way to test that is check for a ground signal with a test light. I would have to see a wiring diagram to know which wire. Didn't see a ton of older cruisers when I worked for Toyota but this is how they did it with most of their cars. If you don't have signal you have an issue with the CKP or PCM. Or wiring in between.
There is no crank position sensor in a 3FE.As far as my limited knowledge goes and what I've learned from my experience in this whole thing, (do not take this info to heart) I think if the coil and igniter still fire a spark, the pickups in the distributor kill it from no continuity and will not reach the plug wires and plugs (in my case that is). I swapped coils with a known working one and still did not fire up. Again, I am probably way wrong and would wait for a more experienced person to chime in. Please absolutely correct me if I'm wrong. Lol
So, i used my test light and pulled the connector from the coil and tested the both pins, one on "crank", one with ignition "on". Ignition on worked fine, crank showed no lights at all.I apologize. I should not have responded till I looked at the diagram. Looks like the Black with green tracer at the coil is your positive wire and black with white tracer is your signal. Key on you should have power. With a test light and a helper check the black with a white tracer for signal ground. Crank the engine while you have the clip from the test light at battery positive and the point of the test light on the negative pin of the connector. The test light should flash quickly if you are getting good signal. Let us know what you find. Again sorry about the mix up.
You have not answered the most basic question:So, i used my test light and pulled the connector from the coil and tested the both pins, one on "crank", one with ignition "on". Ignition on worked fine, crank showed no lights at all.
I have three ICM's that i can play with, but assuming those aren't the solution, its looking like a distributor? I ordered the EFI relay because it was cheap, distributor though, didnt budget for that one. I hate "throwing money" at problems. i paid 65 for the stupid coil at autozone already.
You know, i totally overlooked it and spaced it. No engine light comes on. Only AT Temp, Voltage light.You have not answered the most basic question:
Is the CHECK ENGINE light illuminated when the key is in the ON position before the starter motor cranks.
No CEL=No start. No need to crank the starter as the ECU has not energized the rest of the EFI control system.
