The motor needs to be at top dead center and then the new distributor would get installed with the rotor pointing to #1. Sounds easy but takes some patience and understanding so research is key
Don't you need to mark where you pull the distributor out so that it matches when you put it back in?
It is the only way to test, but you need to be doing it correctly with your meter set up correctly. It should read between 140-1.8K ohms. Coils don't fluctuate. They can be open (infinite ohms), internally shorted (lower than normal ohms or a 0 ohms) or read somewhere in between. They are not an active component so the reading will not fluctuate. If the meter reading is "all over the place" then you're not making good contact.So I am trying to test the distributor and I don't think im doing it right. I'm checking for ohms on the three pins G - G- and NE - G-per the FSM and the readings are all over the place. Is this the best way to test?
Are you certain this meter is measuring resistance (ohms)? This doesn't sound right to me. If you weren't making good contact, the reading would go high (infinite or open), not read 0 ohms (short).Yea, my meter would read a quick 100 or so value then drop down to a 0 until I lifted off and remade contact. So it would never really actively fluctuate (incorrect word usage on my part). It would fluctuate in the sense that I would get a different reading every time I would remake contact before it dropped to 0. Does that make sense?
Man that distr. has quite a bit of rust in it.
With that cap being like that you might want to replace that and check continuity on the coil wire as i bet it is no good
Meter dial should be in the green section with the omega symbol (upside down U) and at the 2000 ohm scale.Yea, thats what I though too! Also, I just switched my multimeter to the 2000 setting rather than the 200 and I am getting a solid 249 reading on G- to NE wire on distributor and getting a 1 or no reading on G- to G wire.
OK, so it looks like the G coil is open. "1" means infinite or open. Spinning the rotor is meaningless here. You're measuring across the pick up coils themselves.I put the meter in the setting you specified and when I touch the two probes together I get a 000 reading and when the probes aren't touching anything, I get a 1. When I touch the G - G- I get a 1 reading. The other NE - G- I get a 249 reading. So one of the pickups has an open loop? Is that determinate of a bad distributor?
I also touch one of the wires and then touch the base of the distributor while spinning the gear and it reads an open loop (a reading of 1).
thanks jon!Talk to @arcteryx Jason @ Cruiseryard.com for all your used parts needs. He's a good human.
Awesome!! We found the culprit. Thanks man! So would a new one from my local parts store not be good?
