I took my land cruiser through some rough off-roading and now it will not idle without the choke at least half way out. I've done the following to try to fix this.
But I still have the same problem. It sounds like the solenoid is fine but I'm no mechanic so I have no clue what I'm looking for or listening for there. Just from what I read in threads here. I included a picture of the carburetor where I found a rubber line broken (have no idea what this is), but I held it on to where it belongs and the car still won't idle without shutting off after a few seconds.
Also, in a picture you see a hose coming from the air filter that in my opinion fits on very loosely (took it off for the picture). Not sure what this is either or if it's lose fit matters.
Any help would be awesome! I love doing this work myself but this if my first time actually working on this car myself and now I'm getting very frustrated trying to solve this.
I also hear some loud gear noise after the off-roading, which goes away when I depress the clutch pedal a couple inches. I feel like this had something do with me letting my oil get so low.
The truck drives fine with the choke out at lights and such.
- My radiator was somehow full of mud so I completely flushed the fluid and put new coolant and water in. (see image of the mud under the radiator cap) The reservoir was also full of mud.
- I had failed to keep up with the oil and noticed it was virtually non-existent on the dip-stick. I changed the oil and filter. Some small metal flakes were found on the inside of the plug. I put 10w-40 oil with a bottle of Lucas heavy duty oil stabilizer because of the high mileage. The oil pressure runs pretty high between the mid and high mark on the gauge. Is that too high?
- I put in the gas tank a small bottle of carburetor cleaner.
- Replaced spark plugs (which looked really bad in my opinion)
- Replaced the fuel filter
