PabloCruise
I am amazed at how many of those marker lights get put back together incorrectly...
Pablo,
Please explain, I'm not seeing it.
The lampholders in the originals were totally rusted out because the PO put them on upside down and water couldn't escape through the little drainage holes in the rubber gasket.
Stumpo,
Great update, you've been busy. I like everything you're doing.
I would definitely make a guard for the filter. I've got to do the same.
On the swingout, What's your idea on bracing. Would it work to move tire closer to the spindel and not have a long swing arm? One day I'll have to make one and I'm always kicking around ideas.
Good Job!
People put them back together upside down so the water enters the light housing, but cannot escape...
Its pretty noisy but then I don't have any carpet or sound deadening whatsoever...I think the 2H might be slightly noisier being a diesel, I just remember the 2F in my old FJ40 had a real loud fan noise.....I have been thinking about drive train lately and was wondering if that diesel is much louder than the 2f and does it drag on those long up hills like tha 2f?
How did you cut that hole in the fender for your snorkel? It s perfect!
Stumpofj40,
Looks like the bearing surface is good, on the spindle. I'd just clean it up and use new seals, of course. Looks like it took in some water.
Snorkel is coming along. Does it get paint when done.
If you rotate the pinion up, I am pretty sure you need to run a double-cardon joint in the shaft up at the t-case.
If I am correct, flanges need to be parallel for regular u-joints.
