Hey all, sorry for the thread as I'm sure this has been covered. I'm a thousand miles from home, short on time and without a PC, so my search ability is limited. I'm hoping somebody might have a suggestion for a common problem like mine on this chassis.
My Cruiser had a sudden problem tonight. Coming to a stop it nearly stalled and all electronics turned off, then back on, headlights dimmed and voltage read around 10v on the stock gauge. As soon as I touched the gas it came back to life and all was well.
It did this a couple more times when coming to a stop. Changing into neutral fixes it. Touching the gas fixes it.
I had the alternator tested at O'Reilly's using their handheld tester on the battery and all tested good.
Using my Bluetooth OBD2 scanner I watched obd2 voltage and it sits around 12.5 while driving, dropping to about 12.1 at idle. I wasn't able to witness a dimming/near stall with the scanner so im not sure exactly how low it gets when it has an "episode".
99 LC, 236k miles, unknown alternator age, die hard platinum group 31 AGM battery that's 18 months old, a stereo amp for a sub and otherwise all factory electronics.
Any ideas? I have a lot of driving in town, Denver, CO, in the next few days, then a 950 mile trip back home to Phoenix this weekend. A break down would be really inconvenient...
Thanks!
-Andy
***Update:
Issue appears to be fully resolved. Alternator was found faulty after a test at Sears and was replaced.
Voltage while driving is now 12.8 or 12.9 via my bluetooth OBD2 adapter. The alternator seems like the culprit. I think the low voltage after leaving the Sears where it was replaced was just due to the battery needing to charge back up. After many hours of driving in the last couple of days (~1000 miles) it's nice and stable and the voltage dips are gone.
The O'Reilley false pass really threw me for a loop on this. My first thought when the voltage dipped was that the alternator was going out. I quickly dropped my wife off and hit the local parts store. Their tester said all was well and I started chasing other leads and started this thread. If the O'Reilley tester could have found the fault I would have bought an alternator and replaced it myself in the street/parking lot and saved the $260 in labor from Sears. Oh well.
So as a PSA to everyone else... Don't necessarily rely on the handheld alternator tests!
Thanks!
-Andy
***Update:
