Moroso makes an aluminum one that fits this bill. It has a petcock on he bottom for draining and a small air filter on the top.
Ran one in the past ....
I am running this one:
http://www.ebay.com/itm/On-3-Performance-Oil-Air-Separator-Catch-Can-LS1-LS2-LS3-LS6-LS7-LSX/151766514712?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=0e3b909db1fc469d921013eea732257e&pid=100005&rk=1&rkt=2&sd=141734826518
I put a stainless pot scrubber inside to try condensate better. Seems to work well so far.....
Found some 5/8 barb fittings for it to fit
I like that. Nice big ports, which is the problem with finding a catch can for our trucks.
I don't hear a knock. Well, I hear something in the beginning but I'm assuming it's wind or your hand hitting the microphone.
Regarding the blowby... if you can not find a catch-can with at least 5/8" or biger ports, don't use a catch can. Just run the valve cover breather to a 4' hose and let the hose dangle (a la Cummins engines in the early 1990s). A small catch can will cause pressure issues and possibly blow out oil seals.
RPM issue... you revved the engine, then the RPM dips low and comes back up? That seems sorta normal. Especially if cold.
When I removed my ACSD I did not re-time my engine. However, I also run about 1mm advanced (pump is tilted 1mm past the hash mark on the timing case). Advancing the timing will reduce your EGT by about 150-200f (measured pre-turbo).
Main pulley: Is the replacement one you just installed... new? I ask because (and consider this a public service message): anyone buying a used 1H(x) motor... you should nstall a new main pulley. These are known to crack, slip, come out of balance, and eventually eat the crank nose (ask me how I know). It's a common problem on these motors that most of us North America peeps (ie: US and Canada, eh) are not aware of because we just don't know these motors very well; any many of them are low mileage JDM motors. A new balancer is a couple hundred bucks. You have to tighten the piss out of the main bolt (I red-lock-tighted mine also, and torqued with a 500lb impact).
Its a kind of damper I think,it regulates the idle,stops it from fluctuation,.
It also stops the engine from stalling when you back off on the accelerator quickly.
Its suppose to be set when the pump is on the bench,then you use the idle screw or hand throttle to increase/decrease the engine speed.
Let me first start out by saying the oil pressure is great, never drops below 18 when hot and gets up to 45+ with rpms. 145k km's on the clock and the BEB's have been done by the PO.
considering the bearing halfs touch each other, i find it strange that the bottom "turned" ...
what about the other half, what is the back of it looking like.
also, considering the oil feed hole isn't lined up i find it interesting there is no oil stain on the casting.
you sure this rotation didn't happen when pulling the crank out? sometimes there is a bit of suction and the bearing can move upon removal.
