Picked up this Superwinch Husky10 yesterday and decided to do a little mock up to see where the best placement would be
At first, I wanted it on the driver's side, but due to the motor location pushing the drum towards the center, the cable just won't line up with the secondary fair lead I plan on mounting on the x-member between the left wing and the hitch
So I tried the passenger side and it looks to be a much better fit
Seems to line up perfectly and looks like there's plenty of room to play with...
Also looks like it will be tucked away nicely...
Mounting may be tricky due to the wing braces....
I'm thinking about just getting a 40"x10"x3/8" plate and welding up 4 large angle brackets, then bolt the brackets to the rails using 8 bolts
(longer versions of these)
I figure the brackets should give the wing braces enough clearance for removal if necessary
I'll most likely mount a small ATV sized steel Hawse between the camera and the trailer plug
I'll be picking up supplies this week, but I'm open to suggestions.....
