Poser said:Only the tcase input gear and the PTO, as they ride on the trans output shaft.
Mace said:They are very easy to put back
theo said:Mine has a spacer in place of the PTO gear. Either way, simple to install.
Poser said:There could only be two gears on the shaft, and they can only be installed one way.
Don't sweat it!
Blue77FJ40 said:Then there's the old quandry - does the open side of the tcase seal go towards tranny or towards the rear :^) Mine had the spring facing the front from the factory
Poser said:There is no quandry- The spring goes towards the trans, period.
