LinkBack (15) Thread Tools Display Modes
Old 07-29-07, 05:10 PM   14 links from elsewhere to this Post. Click to view. #1 (permalink)
THC
Trollhole's Avatar
Garage
Big Gay 2F Build Tech
A little history on why it's gay. The Big Gay 2F Build
But the color is not the focus in this thread.
I'm starting out with an 86 2F.
Little is known about the motor. But it was just currently driven from CA to SC about 3 weeks ago. From what we can tell the motor has over 250k on it possibly more. Ran great. No idea on knowing if it is a rebuild.
Compression numbers were
#1 135
#2 135
#3 135
#4 105
#5 135
#6 135
I wouldn't have touched the top end except for the #4 cylinder had me worried.
My plans are to totally desmog it and add TBI. Top end is going out tomorrow to the machine shop to be redone. I have rebuilt a couple top ends on f motors but never dug into a 2f and never the bottom end. But my goal is to have a nice smooth strong 2f.
So now here is where the tech starts.
Cylinders
#1
#2
#3
#4 the problem cylinder
#5
#6
Rear three cylinders
Front 3
Front three chambers
Rear 3 chambers
other pics
o26Qz
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
Originally Posted by grant5127 View Post
Having a motor that doesn't have enough power to pull a sick whore off the piss pot would be hard to ignore........
Trollhole is online now   Reply With Quote
Old 07-29-07, 05:22 PM   #2 (permalink)
THC
Trollhole's Avatar
Garage
So now the questions.
Due to the low compression on #4 I'm at the least replacing the headgasket and sendin the top end out to be rebuilt.
#1 Should I have the head shaved to add a little better performance? And if so how much?
#2 Considering I can still see the crosshatches on the cylinder walls and no scoring should I just put new rings in and clean the cylinders up?
#3 I'm pulling the pan, should I replace the oil pump while I'm in there?
#4 Also I will have the bottom end open should I replace the rod bearings and main bearings?
#5 I'd like to yank the front pulley. Anyone know the size Of the crank nut and if I could borrow the parts from autozone or advanced auto? I'm assuming I will need a puller.
#6 If the pistons end up being ok is there any benefit in having them balaced with the crank.
#7 Assuming all this other stuff is getting yanked should I go ahaead and yank the crank and replace those bearings also.
#8 Is there that big of a difference in a RV cam vs a OEM cam.
#9 Any other tips I should know?
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 07-29-07, 05:38 PM   #3 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
Garage
Cut .030 off the head...look at the head where the rocker cover gasket seals...and see if anyone else has ever cut the head...if they have, they may have stamped in what it has been cut.
Run a hone through the cylinders, get some new rings and call it good.
You can replace the pump if you want, but if it has been working, I would run it....take it apart and look at it...if nothing else, turn the gears over....see the 1979 H55 thread for more info on this.
I would roll new bearings in....they are cheap.
Crank nut is 46mm
Old 07-29-07, 05:40 PM   #4 (permalink)
grant5127's Avatar
I would make sure that scoring is gonna clean-up first... looks kinda deep.......
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|_____________________/||__|___|
The Beer Truck, that ran over Bunny.....
(\__/)
(")_(")
grant5127 is offline   Reply With Quote
Old 07-29-07, 06:44 PM   #5 (permalink)
THC
Trollhole's Avatar
Garage
When I saw that pic I though the same thing. It was just some carbon that had left that. Inspected all cylinders and all are free of score marks all smooth as glass and all still have the cross hatching.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 07-29-07, 07:01 PM   #6 (permalink)
phocus's Avatar
Fantastic thread, pictures "ARE" worth a thousand words. I see now I will need to dump my f motor and look for a new one, or do some major machine work.
phocus is offline   Reply With Quote
Old 07-29-07, 08:08 PM   #7 (permalink)
grant5127's Avatar
Yea.. when you get the piston out it will be equality scored.. ( carbon, stuck ring) you can clearly see the path marks.....
(\__/)
(")_(")
Old 07-29-07, 08:26 PM   #8 (permalink)
Dynosoar's Avatar
That #1 looks bad I don't think you could hone it out. Does it catch your fingernail if you scrape over it? If so than most likely it wont hone out.
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic, Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is offline   Reply With Quote
Old 07-29-07, 10:18 PM   #9 (permalink)
1973Guppie's Avatar
great thread, I will need to do the same "inspection" to a 2f here soon for my 55 project, so this info will really help to know what to look for as far as engine condition as I will only want to redo the top end of the engine.
and something to add to the gayness..
1973Guppie is offline   Reply With Quote
Old 07-30-07, 07:01 AM   #10 (permalink)
THC
Trollhole's Avatar
Garage
Dynosoar
Just imagine making those marks with a pencil. Thats the extent of which it is on there.
Like I have said the cylinders are free from score marks.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 07-30-07, 08:06 AM   #11 (permalink)
FJBen's Avatar
Jeez, I'm "de-gaying" my 350....it's purple but not for long...it's on a stand in my garage...and it will be painted..
FJBen is offline   Reply With Quote
Old 07-30-07, 01:51 PM   #12 (permalink)
THC
Trollhole's Avatar
Garage
Dropped the head off at my machine shop.
$80 to redo the valves and install the oil seals
$60 to shave the head .030
I also decided to have them hone the cylinders since it sounds like I could possibly mess it up. $30 dollars
Best of all they are going to clean all my bolts, parts and whatever I give them for 15 dollars.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 07-30-07, 02:04 PM   #13 (permalink)
what he said
Mace's Avatar
You will probably have to say this three more times.
1. shave away
2. Hone and rering..
3. check clearances in the pump, when they are within spec, run it (most likely they will be)
4. Replace the bearings, all of them. It really is not that hard at the point you are..
RV cams are great. I would do it.
You are basicaly going to do a mild rebuild on this motor. Mingt as well do it and not skimp..
I am kinda gay.......
I've set the bar, don't trip over it....
Old 07-30-07, 02:09 PM   #14 (permalink)
Sputnik40's Avatar
When I rebuilt my 2F (Capt. Jim's original FJ40) I had to go 020 over and new pistons. I didn't replace the cam or lifters as they all looked good - I'd be sure to double check them. I kinda wished I'd replaced - but dang it runs great with the FI and DUI, so no worries I guess.
I ran a new oil pump - OEM was not cheap!
Getting the timing gear cover assembly just right was tedious - so worried about overtorqueing with the inch/lb's I was really careful. Other than that - easy as pie.
"The devil made me do it the first time. The second time I done it on my own."
Sputnik40 is offline   Reply With Quote
Old 07-30-07, 02:12 PM   #15 (permalink)
THC
Trollhole's Avatar
Garage
My Toyota Dealer says the main bearing could be #1 #2 #3 #4 and I could have any combination of this. Said they would be stamped on them what the number is. Is this correct?
I'm guessing if I have to hone I will have to yank everything including the cam. Should I also replace those bearings while I'm in there? How hard is that? Any special tools.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 07-30-07, 02:15 PM   #16 (permalink)
what he said
Mace's Avatar
have the shop that is honing your block install the cam bearings..
Old 07-30-07, 02:21 PM   #17 (permalink)
THC
Trollhole's Avatar
Garage
check
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-07-07, 07:17 AM   #18 (permalink)
THC
Trollhole's Avatar
Garage
Is there any value to having the crank, pistons and rods balanced while it is out?
Dropped the valve seals off yesterday. Head has already been shaved .030 and the valves have been done.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
Old 08-07-07, 08:28 AM   #19 (permalink)
'74 UA FJ's Avatar
I would balance them. Engine vibrations will drive you crazy.
1974 FJ40 FI vortec 350, H42/Orion 4:1, 35x15.50 SXs on MRW beadlocks, lock-rited f/r, Saginaw ps, 30 Longs, 6 stud hi-steer, etc, etc.
1994 FZJ80 with factory lockers and 285 revos.
'74 UA FJ is offline   Reply With Quote
Old 08-08-07, 06:51 AM   #20 (permalink)
THC
Trollhole's Avatar
Garage
Well it's a 2f . I'd expect vibrations. Didn't know if it was worth the $$$ to have it done.
Marshall
Upstate Cruisers
TLCA
RIP Andrew Farmer
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/168967-big-gay-2f-build-tech.html
Posted By For Type Date
Subzali aka Matt Miller and Brahma - Rising Sun Member Forums This thread Refback 11-14-09 11:19 AM
Anyone know Brian Mcintosh? - TTORA Forum This thread Refback 09-10-09 01:47 PM
Favorite LC Pics Thread - Page 7 - TTORA Forum This thread Refback 04-16-09 11:08 AM
Straight axel eliminator kit? - TTORA Forum This thread Refback 03-30-09 02:13 PM
What to look for in an FJ40 - TTORA Forum This thread Refback 03-15-09 12:16 AM
Motor Vehicle Use Maps - TTORA Forum This thread Refback 03-06-09 07:51 PM
Straight axel eliminator kit? - TTORA Forum This thread Refback 02-10-09 04:20 PM
Hello from Gvl, SC - TTORA Forum This thread Refback 02-04-09 04:20 PM
Hello from Gvl, SC - TTORA Forum This thread Refback 02-04-09 02:38 PM
Favorite LC Pics Thread - Page 7 - TTORA Forum This thread Refback 02-04-09 09:53 AM
GSMTR 09 June 15th-21st - North Carolina 4x4 Forum This thread Refback 01-29-09 02:48 PM
Yota - Carolina Broncos Forums This thread Refback 07-15-08 10:27 AM
400 HP turbo 2F tuning - OFFRoad-Bulgaria.com This thread Refback 03-09-08 12:42 AM
400 HP turbo 2F tuning - OFFRoad-Bulgaria.com This thread Refback 03-08-08 04:57 PM
motorgaurd filter assembly - (air dryer) 40.00 - Rising Sun Member Forums Post #0 Refback 01-30-08 02:08 PM
