I have read every thread on this forum dealing with whether converting a pre-03 LC from factory NAV to double din with separate climate knobs is possible. What I took from all of this was that the experts on Mud thought it was possible but it would take a great deal of research, time, money and effort. There are some that think that it would be possible using components sourced from European models.
I pulled my NAV unit and took a bunch of pictures so I am hoping that our fellow Mudders can take a look at what I have for wiring harness connections and tell me if they think it is possible.
I plan on keeping my LC for many years and it would greatly increase my vehicle's reliability if I had separate NAV, climate and audio functionality.
Please post anything that would contribute to making this goal possible. Sorry about the pictures. I only had my Nexus One on me when I started this.
Here is what I started with:
In order to get to the NAV/Climate/Audio unit, start by prying off the trim panel. I used a putty knife wrapped in a chewing gum box to protect the trim.
Once the trim panel is off you can see that there is a connection running from the harness that connects hazards, center diff, power antenna, outside temp, time, time set buttons, rear defrost, rear fan, and heated mirrors.
Here is what I found on this connector:
After unplugging the connector for the front trim piece, remove the 4 screws surrounding the unit and gently pull in out. There are basically 3 rows of connections on the back of the unit.
Finally, remove the connections for Main and Sub antennas.
