Yet another question on tailgates
Santa Rosa, CA
Can someone edumacate me on tailgates? Were they available from the factory? Are there sources? Searching I found pictures of the bandy's, but no sources. On ebay, there are a few people selling new tailgates that look like barn doors welded together for $550. There's a used one on ebay for $750 which seems expensive. Awl_teq makes a great one, but for the 45 only and I want one for a '66 fj40. I'm tempted to go with the new one on ebay as it all set up for hinges. Toyota Land Cruiser FJ40 Drop Down Tail Gate | eBay
Fst 40’s got them and 45 short wheelbase pickups from the factory. Over the years they have become harder to find and more expensive. The hardware and latches and correct chains are almost as much as a tailgate!
Thanks for that. I should add I also found a bolt on tailgate at SOR for $425. Also, although the chains were original, I've also seen a couple of pictures of latches that looking like a version of the windshield latch. And, real steel offers a drop down for $550 that looks exactly like the one on ebay at the same price - hmmm.
Should mention the tailgate only came on soft top models. Early soft top models came with either tailgate or barn doors. By the mid sixties all soft top models had a tailgate that were imported to the US. There was a third option for the soft top model but those were never imported to the US. There are also two versions of tailgate. Earlier ones have a wider middle section. I posted pictures of both side by side in the past.
Just checked the eBay link. That tailgate is made for the 75+ cruisers here with the spare on the left side and license plate on the right.
The eBay tailgate is from Real Steel.
Keep in mind the new tailgate offering is set up for a driver’s side tire carrier, passenger side license plate.
I have a four plus bump, so that doesn't matter. I might even see if I can get without.
pretty sure that if you order directly from real steel, it asks you what side you want the plate mounted to.
this is a realsteel and i love it...one of the best things i did.
Sweet - I'll do that. Did you look at using the latches instead of the chains.
Where did you get your latches?
This is also made to used the 2/74 and later license plate bracket with two lights. If you want the license plate mounting bracket switched to the left side odds are this is not the correct bracket. Unless your looking for OEM correct the newer style is a better bracket.
If you want to be technical John, the FST continued to use a right side mount past ‘75 even though it switched over to the left side for the hardtop models.
Where are you getting the hinges? I’ve been on the hunt for over a year for some, missed a few opportunities in the classifieds for even single ones, I have one original left over from the rig. I still have time to hunt, but I’ve already started to think about making them. As many rusted gates as there have been posted in ads without hinges I think there must be a pile of them somewhere, probably with all the missing single socks, lol.
BTB still has the hinges, the show out of stock on the latches. Any idea where the latches are available?
they used oem....one side was still available new, the other was disco...so they cut one of the wrong side up and "reworked" .....looked like s***. i ended finding a decent used one to run.
chances are the side that was still around, no longer is.
So, when I went to order the hinges, they are on back order. BTB doesn't have the best reputation. Safe to order something that's back ordered from them?
