Would U Rhino Line
your roll cage?
As everyone knows, I purchased the Full Cage from Metal Tech and we are finally getting around to the assembally. We should be finished with it next week.
Since getting the the price on the welding, my pocket book is really starting to feel the pinch and the CFO (my wife) is pissed about the one way drain. My intentions were to powder coat the cage, but the cost of doing so is much greater than it would be to rhino line.
Nonetheless, I'm pondering the idea and wanted to get some input.
Thoughts, please....
No, I wouldn't.
I would go spray bomb, b/c then if you modify it's easy touch up as needed without having to re-rhino spots. I would think much cheaper this way too.
But that's just me. I don't have the high dollar super clean rig many of you own.
not rhino line, do it with a do it yourself kit, I used herculiner on mine along with their topcoat to keep it from fading, 4+ years later it looks as good as new. The nice thing is it is bulletproof and I don't have to worry about it getting scratched or anything.
noah
Noah,
Looks sweet! Do you have a pics of the entire interior and the exterior of your truck? If so, please post....
Thanks.
if your wallets thin and your wifes pissed, rattle can it and be done.
rattle can is prolly easiest and cheapest, plus you can make it look good if you put some effort into it...
X2 - rattle can and install, cheap, easy and reversable with little effort so if you decide to powder cote at a later date it will be easier prep than trying to remove the Rhino lining.
noah
Noah,
What 2 sizes are the guages in that cluster, as I am planning the same setup.
Sorry, Hi jack off.
Uno,
there are a boatload of pics on my sig line, under imagestation.
Old Iron, can't remember the exact size but they are autometer and the guage panel I got from man a fre awhile back I think, I cut one more hole in the center to squeeze in another guage. The smaller guages are the smallest ones ameter makes and the larger ones are the standar tach and mph sizes. I really like the mph guage as it is electronic and I can reset it easily when changing tire sizes, slick.
Noah
Just paint it. If down the road you want to modify it, that liner could be a big problem.
I like the hurculiner deal better. I've done it in Jeeps a few times and holds up great. You will never have to worry about "touching it up" like from spraypaint because it's not like you'll be able to scratch it. Hurculiner also has some minor sound and heat insulation.
