Wore-out steering box
The hard part is that there are 3 bronze bushings that need to be pressed/driven in. They are over size and need to be reamed or honed to the correct size. Most machine shops won't have trouble doing this, but I would guess they would want at least $100 to install and ream the bushings.
Also, if you are buying a used one, how do you know you're not buying someone
else's used junk? I bought a used one to rebuild, so that i could learn how to
do it without disabling my cruiser. Found the used box for $40. Bet you could
do the same.
1972 was a transition year. Early '72 had the box without the rag
joint, where the box and the steering column are one part PITA.
Later '72 had a rag joint, separating column and box much easier.
See: http://www.sor.com/sor/cat098.tam?xax=4601&page.ctx=cat098.tam
Where are you located? I have one off of a 78 FJ40 if it will work.
672FJ40 said:
The box I'm dealing with is an early '72 (no rag joint). Is there anyone out there that wants to unload one? I'm in Houston.
i just pulled one off of a parts 40 on saturday, and everyone is right in sayin that the one piece is a total pain...
no idea on condition (from the rest of the steering stuff, it looks to have seen an average amount of wheelin, but nothing to break any stock stuff; but again, i never drove it...)
if you want it as an exact replacement 10+ shippin would do for me, but if you want, i would switch over to the rag joint (abt a billion times easier to work with/remove) and pick up the one that fj40mayo is tryin to sell you...
and if the rubber on the rag joint is sloppy, i know you can pick that up at the dealer, but it might cost you a bit (40-50ish??? IIRC)
malphrus
malphrus
Not encouraging anyone to do anything dangerous, but the rubber in the rag joint looks like a chunk of the belts out of a tire...is it reasonable/safe to cut a new one out of a tire carcase?
Kirk
the one that clemsoncruiser got last month looked fairly complex for a tire-hackjob, but it would definitely be feasible... i hate payin for em, but man do i love the look of new oem parts, ha ha
malphrus
Pmed ya. :)
672FJ40, are you coming to the Round-up? I will bring the one from my 78 if you want it. A 6-pack of Cold Brew will be payment enough.
later,
You can easily bolt in the later style box with a rag joint which is a much better design. You will need the column, too. The 'one piece box' is a weak roller type vs. the later type that has a sector gear. Much tighter.
Hey all, I have a question. After refurbishing my 2/71 steering box [ http://tinyurl.com/4ehfr still working on the write up so bear with me] (Put in new seal, adjusted the slop out, did NOT replace the bushings or bearings as they are still OK but did swap out the sector shaft as the sector wheel had a casting defect in it)
I got to looking at the 1977 steering olumn I bought in anticipation of my PS conversion later. Will the late 72 and up manual steering box mate to the 1977 column? I was thinking if it would without having to hack on the 77 column then I would get a used later syle box like FJ40Mayo has now and go ahead and mount the 1977 column. One less thing to do when I do the PS install. BTW seals, gaskets, shims and bearings are available from Marks Off-Road for the early boxes.
