Won’t start after maintenance
The crankshaft has to be rotated to piston TDC on compression stroke. Rotate the crankshaft 180 degrees and it will show TDC on the pulley but you will be at the transition from exhaust to intake.
Correct. That is why I wanted him to check for spark and also look to see if he is 180° out (in my previous posts).
These are fundamental things to check before looking elsewhere.
Rotor is definitely in the right spot when the harmonic balancer is set to “0” and the piston is at TDC. Also as you guys have stated, it could be on the wrong stroke. Not sure if I stated before but the coil was throwing a fat spark and I confirmed today that I’m getting spark on the first 2 wires(didn’t check the others after those two showed spark)
I don’t have a timing light but I suppose I should get one. As of now, there has been no start where the rotor is or 180 degrees from where it sits. It sounded like it wanted to start the first time i cranked it over on its current orientation but no dice on running. There’s fuel on the spark plugs so I suppose I fouled them. Where’s that gun to the head emoji...?
So to recap.
  1. You have a CEL light at the dash when you turn the ignition to 'on'?
  2. You have checked for spark and have spark on at least two of the wires?
  3. You double checked the distributor orientation and it IS at TDC pointing at cylinder #1 (on the compression stroke)?
  4. You have fuel on the spark plugs?
Questions:
A. When you pulled the distributor did you make a mark on the body relative to a location on the block so you could return it to its approximate former timing?
B. I see you have new looking aftermarket plug wires. Were these replaced at the same time you were doing the other maintenance?
Notes: IF the distributor was not returned to its prior 'timing' position, you might have someone rotate it while you are cranking the engine to see if you find a spot where it wants to start.
Also double check your firing order if you replaced the plug wires when you did the maintenance.
If you are getting spark to the plugs and you are anywhere near the correct timing (and firing order is correct) then you likely have a fuel issue.
You are SURE all electrical connections are in place and in good order?
First, remove #1 spark plug. Stick palm over spark plug tube and spin the engine over clockwise, when you feel air pushing out of the tube continue to rotate the engine and line up the timing mark with the 10. Reinstall disty so the index mark and pick-up line up(green arrows in picture) with disty bolted down.
This will get you in the running ballpark for #1 TDC at the compression stroke.
1904435
There is also a wire that feeds the power that runs near the disty and plugs into the harness at the front of the manifold, is it hooked up?
I do have the CEL on with the key on and can clearly hear the EFI relay click
I have checked for spark and am getting spark at the first 2 cylinders(at least...that's all I checked)
I do have fuel on the plugs
I do have the rotor at the correct orientation at TDC(not sure if its on compression stroke or not although it's not starting this way or 180 out)
That pic above shows the rotor a little off of where I have it now. Its now between that and 12 o'clock at tdc
I did not make a mark when I removed it but I don't understand how the timing could be that off...(as far as rotation of the distributor)
Firing order is definitely correct, I've double checked that. I didn't replace the wires. They were already NGK when I got the truck 30k miles ago but I think weren't very old IIRC from the PO's maintenance records.
What wire are you talking about near the distributor and manifold? As far as I can see double and triple checking everything...all plugs are accounted for and plugged in. Every sensor, every plug wire, coil...everything. It has to be something dumb...I know my luck
CEL being on is good. EFI 'clicking' only means the contacts have activated, does not mean the relay is good.
Spark at the plug wires is a good sign but is it a good spark? Test the resistance at your coil so we can eliminate that. Set a multimeter on the ohm setting, probe between the - and + terminals and see if you have between .36 and .55 ohm. Then check the secondary coil resistance by probing between the + and high tension terminal. You should see .45 to .65 ohm (cold).
Fuel at the plugs probably means your fuel system is working but I would crank the engine, turn off then go and carefully disconnect the fuel return line at the Fuel Pressure Regulator just to confirm you have good pressure.
I agree that you are likely close to the correct distributor setting. IF want to be sure you can pull the #1 spark plug drop a long wooden dowel down onto the top of the piston and slowly HAND turn the engine watching for the dowel to reach its peak lift and looking for the corresponding mark (TDC) on your balancer. That way we know you are on the compression stroke and not the exhaust stroke.
If we know the firing order is correct and you haven't changed any of that then we can dispense with that idea.
Basically we have to establish (without a doubt) that it is getting good spark and getting enough fuel before we move to checking other things.
At any point has the engine tried to 'fire' at all?
This does nothing about telling you what stroke #1 is one, just confirms that the cylinder is at TDC of either the compression or exhaust stroke.
Yours might not have the wire, it might be a OBD1 specific item. I didn't see mine and forgot to hook mine up and no start. I'll try and get a picture later on today.
If you have a good helper you can have them try and start it while you are turning the distributor slowly and see if you can make it pop some.
Does it make any noise at all??
I agree that this is going to be something really stupid when you find it...
I'm curious to see the wire you're talking about and I'd love for that to be the issue.
So yesterday, I flipped the dizzy 180 and tried to start it(after I established spark from the wires) and it fired like it wanted to start but immediately died and wouldn't run. After that, I couldn't get it to fire again...only crank.
I really appreciate everyone's responses on this trying to help 🙏
another question...disconnecting the battery wouldn't trip anything or cause a non starting issue would it? Like an immobilizer?
Some plugs foul really easy. They will not spark under compression but will spark when you have them out. Try a new set.
True, I should have included this will be in conjunction with the rotor pointing to the number one cylinder port on the Dizzzy cap. That way you know you should be on the compression stroke and right at the top of the stroke (not past it).
No, because if the distributor is not aligned properly and if that is what you are trying to accomplish, it will NOT be the case.
The VALVES must be closed, so you must determine if it is on the compression stroke by using either a compression tester in the spark plug hole or something to sort-of plug the spark plug holes to determine it is coming up on the compression stroke.
THEN you can set the distributor accordingly.
TDC on the COMPRESSION stroke.
I mentioned using a screwdriver method up above to verify the position of TDC of piston #1.
Yes, that's correct and a great way to determine that it's on TDC, but it will not determine if it's on the compression stroke. Remember, the engine turns two times for every complete firing cycle.
Right but easily rectified. If you aren't on the compression stroke the first time (and you didn't mark the dizzy and have it in there all wonky) then you may assume you are 180 out. Pluck the dizzy turn the engine so that the piston is coming up again, stab your dizzy (remember the gear is helical so you'll need to lead it some) and fire the damn thing up. Its not complicated for anyone that has done it before.
It doesn't require any special tools really. You are either TDC on the compression stroke or the exhaust stroke. But I'm not sure that is the OP's problem.
Easy to assume as I assumed that as well but I've tried it both like it is and 180 from where it is and no dice...
To be clear you have pulled the distributor, put your palm over the spark plug tube while turning the engine (by the crank bolt) so you can feel when you are on the compression stroke. Brought the timing mark to 0 (TDC), then installed distributor with the rotor slightly advanced so that when it seats it ends up pointing at the #1 port position on the cap? If you are anywhere close to right...and you have spark and fuel then you should be getting a 'pop' from the engine. It might not start...but it should be trying.
Don't make me drive to San Antonio. ;)
OP's problem is that he put it back together and is not sure he put it in the right place, and it won't start.
So, he must start at the most basic level and must determine that he has TDC on the compression stroke. Period.
