Won’t start after maintenance
you're right, I'm not sure which stroke its on but I know its right on TDC...just not sure if it's 180 out and its not firing either way. Like I said, it attempted to start where it is now so I'm assuming this is the compression stroke but I haven't placed my hand over the no 1 spark plug hole to test that yet
I'm just as baffled as you guys as this doesn't make sense...wondering if the plugs are fouled but I cleaned and dried them and re-installed them
The truck has the factory installed Toyota alarm system but I (thought I) disabled it last year when I couldn't disable it and start my car before. That time it wouldn't even crank...
OP's problem is that he put it back together and is not sure he put it in the right place, and it won't start.
So, he must start at the most basic level and must determine that he has TDC on the compression stroke. Period.
Agreed. And we told him several times and several ways to achieve that. It is hard to move on not having empirical evidence that certain parameters have been met.
Like you, I am trying to keep this simple and address the most 'likely' reasons the engine won't start.
We know we have to have fuel, spark and compression for it to fire (basics) but other things like fuel pressure, fuel mixture and timing come into play as well. So hopefully, he will be able to start scratching some of those things off the list soon.
If he doesn't have spark (or enough spark) the plugs are eventually going to become fuel fouled when he cranks it. Its a pain in the rear to chase the issue(s) down sometimes, but it is best done methodically.
First determine what is (and isn't) missing, then determine why. Often times its something simple (no ground, something not connected, etc..) especially if the engine was running before any work was done on it. It's just hard diagnose these things from behind a keyboard in some cases.
Ok. This could be an issue, as the factory alarm tends to freak out.
I would do a methodical removal of the alarm and make sure that all connections are plugged back together.
It’s a ‘97. I know it’s hard to diagnose from behind the keyboard so again, I really appreciate all of the help and suggestions from you guys.
Thanks, that is helpful. Same year as mine...so I can compare parts/components. Also, I have an FSM and EWD for it. So a source for troubleshooting. But...our best bet is to draw from the knowledge the folks on this site have. Don't worry...we will stick with you.
I know you have already addressed some of the following...but can we just sort of go through a 'check list' (for my sake) and be certain we are good in these areas.
  1. CEL is definitely on when ignition is in 'on' position?
  2. MAF sensor connector at air intake hose is connected?
  3. Distributor connector hooked up?
  4. Coil connector hooked up and high tension lead pushed in all the way on the coil and dizzy cap?
  5. Igniter connector hooked up?
  6. Both grounds from coil base connected (one to intake, one to drivers side fender)?
MAF is connected and zip tied the same as yours haha
Distributor is connected(and zip tied)
Coil is connected and was never disconnected
Igniter is connected as well and was never disconnected
Ground wires to the coil are connected and were never messed with
Excellent. Thank you.
And I don't mean for any of this to sound condescending, you sound as if you are somewhat mechanically inclined. It is more for my benefit....just to know where we are.
The last time the engine ran...were there any issues then, or did it start and run OK?
It’s cool, no offense taken. I work at a Honda dealership in service(parts specifically) so I’m a little embarrassed to be baffled by this.
Last time it was running just fine. I only started working on it because it was starting to leak oil onto the ground and I had been putting it off for too long.
I tried to post a video of me trying to start it but it won’t recognize the file type
Is there any indication the engine is trying to start...or just a constant cranking?
* You have PM*
When i just flipped the distributor rotor 180 on Wednesday, it fired the first time I cranked but never started. After that, it would only crank and crank.
I considered spraying some starting fluid into the TB but have yet to do that. Probably try that today unless someone advises against it for some reason
