Won't idle
MA
Recently ran out of gas in my 1971 FJ40 (I know lame move) and now it won't idle. Any thoughts the what the cause might be?
You haven’t stated whether it’s a stock carburetor or not. Not a safe assumption.
Have you checked your fuel pump? It could have dried and cracked the membrane and won’t pump your fuel.
I haven't checked the fuel pump. I'm learning on the job if you will and this truck is quickly becoming a my new hobby. I'll give it a look.
stock carb- is the fuel level in the middle of the glass?
If it’s the fuel pump you’ll need a new one. They can still be had at Toyota, or city racer llc I believe. If it has different connections, you should be able to use the old ones. It’s a quick fix. 2 bolts and a gasket. Good as new..
I'd start by replacing the fuel filter. Maybe you sucked up some crud when you ran it out of gas and the filter is blocked. That's about as simple a fix as they come. Pic's could help.
Your fuel pickup probably sucked up a bunch of crap and clogged the filter causing no fuel.
It's also quite likely one has nothing to do with the other. Start troubleshooting with the basics.
