Windshield Wiper Motor Upgrade?
Cedar Rapids, IA
Had some pretty torrential downpour rains last night and noticed that my 92 FJ80 wipers don't move near as fast as my Camry. Was wondering if anyone has done anything to upgrade the motors to make them go faster. Not a huge concern, I just slowed down but thought I'd check to see if there was an easy upgrade.
I did use the search and didn't find anything...
Thanks.
Maybe you could do something like this
:flipoff2:
That was a sprinkle man...
From my experience playing with something similar, I increased the voltage that was supplied to 14V and it went much faster. I was working with a door motor that wasn't being used for it's intended purpose though. But at 14V man that thing was much faster.
The extra HP and torque provided by the 1FZ makes this a non issue.
This is assuming the wiring harness doesn't get melted rendering the wipers inoperable... :flipoff2:
Even by Florida standards that was a helluva downpour. I didn't video when it was pouring down. I was too busy white knuckling it.
I don't know much about electrical so how could I increase the voltage to it?
I would check the voltage first to see how much improvement can be made. The motor is pretty easy to get to, so just compare volts @ the terminals while it is running full speed and the engine is running. Then check your battery voltage in the same conditions. The difference is loss that could potentially be corrected.
To make improvement, you'd need bigger wires and probably wire in your own relay and fuse. I'd have to review the EWD for a full schematic.
Well start by seeing what the actual voltage IS going to the motor. Your wiper switch/stalk has variable speeds correct? Check the voltage at each setting. At full on you should have full alternator voltage. If its not then it could be voltage drop from wiring, it could be maybe an old/rusty/oxidizes relay? I would baseline it first before coming up with other solutions.
Make sure you're running water on your windshield while you're doing this to get a real world reading. Running them dry will tear them up and they will drag more. Also measure the AMPERAGE on each setting. That may help tell what's happening.
My factory wiper motor had the internal magnets come loose from the housing and stick to the commutator inside the housing. The Dorman aftermarket unit runs slow too, so I'm guessing I also have a voltage / amperage issue. You can also take out the arms and clean and lubricate the joints to help them move easier so they are not robbing power from the already weak motor.
Do they make a 1FZ wiper motor?
The motor has two taps and always gets full voltage to either the low speed or high speed tap when running. To check high speed motor voltage, use your voltmeter connected as follows:
Voltmeter Positive connected to wiper motor plug connector Blue w/ Yellow stripe
Voltmeter Negative connected to wiper motor connector White w/ Black stripe
Compare this to a direct reading from the battery.
He refuses anything to do with pink panty technology. :flipoff2:
FIFY :flipoff2:
I'd allow FZJ wiper motors the honor of being on an FJ80 if they are stronger. I will have to do some trouble shooting. Not sure that the wipers are "slower" than when I bought my 80 23 years ago. I just think they've always been slow and times have changed.
I will check this when I get home. I'm fishing and the bass are biting. :)
Hey just wondering if you ever found any solution for this, or if you were just too busy fishing to bother. I'm having the same problem and am planning on some combination of redoing the wiring to reduce voltage drop and finding a more modern Toyota model's wiper motor that I can retrofit. I wonder if 100 series wipers are any better?
No, I never did. It stopped raining hard and fixed the problem. :grinpimp: But seriously, I forgot all about it. I will check this weekend.
you might also check the wiper mechanism. the bushings where the mounting studs come out develop play over time. this doesn't help the speed neither. easy to check when you try to move the wipers up and down.
FIFY :flipoff2:
They are known to be stronger in many ways, just make sure you don't get a wiper motor with a blown headgasket.
My old 4runner had very slow wipers and I spent a lot of time chasing the problem.. junk yard wiper motors, rebuild the motor/gearbox, all sorts of stuff. What it seemed to come down to in that case was the magnets losing some of their strength.. other than buying a brand new motor I couldn't find a way to fix it.
That said.. the thing looked exactly the same as what is in my '80, with less miles and produced on the same year.. and the cruiser's wipers work just fine. So...
An easy fix to this would be using some Rainx. I seriously hardly ever have my wipers going faster than the intermittent setting, and that when i'm sitting not moving. I've driven 4 hours in a down pour and never used my wipers . Just be sure to apply the rainx correctly to get the most out of it.
Consider that when it rains so heavily, driving at all might be unsafe. Might be best to pull over wherever it's safe and wait it out - rain that hard seldom lasts for more than 15-30 minutes. There are worse things than sitting or napping in your cruiser in the rain.
