Does anyone know where I can find windshield hooks for a 74 40 (the ones that will turn to the front and hook into holders on the hood.) Preferabley stainless but anything is a start.
Rocknroll said:Is it possible to change to the newer style hook, windshield bracket and pad? Or would that rquire changing up the hole pattern on the hood or repacing with a newer hood to make it work?
Windshield hold down hooks changed in 1979, iirc.
The early style have been discontinued for some time....and replaced by the newer piece.
If you have the rubber winshield bumper on your hood with the tall part to the rear, as it came stock, you can turn them around and possibly make the later style hooks work to hold the windshield down... you will also need to modify the center to allow the hold down to pivot/travle 180* in the pivot assembly to the stow position....or find some decent used ones someplace....
I think I know of someone selling a refinished set of windshield hooks.
Contact James at wadesters(at)bellsouth.net
He has a set that he has had bead blasted, primed, and recoated in some aircraft silver coating. He's asking $40 though.
