- Thread starter
- #61
I just discovered that color myself and have been trying to find a mix code and in an industrial type of paint. Would you mind sharing the mix?
Let me see if I can dig it up.
Mark,
I’m still not sure what to do with this older style hinge.
Maybe, make a pin set that is slightly longer than the two hinge pieces (without bushings). Make it so it tightens against the pins and not the hinge itself. Just seems like it would have too much forward and aft movement.
Maybe I’m reading to much into it. I just don’t care for the way it was designed.
You could always swap over to the later three ear hinge.![]()
What I would do if it were me for these old style hinges is this: Supply a pin that's bigger than the original. Have the owner diy drill out one piece of each pair big enough to accept a bushing. The bushing would go into that. Their would have to be a L and R side so that when both are bolted down the two pairs of hinges hold everything together and the hood doesn't slide off to one side. For the other hinge piece of each pair have the owner diy drill it out to be able to press fit the supplied larger pin. A larger pin would ensure any hinge wear is simply drilled out. Hope that makes sense. Just supply the bushings, pins, and instructions on drilling and drill bit size.Mark,
After taking a closer look at your earlier model hood hinge, it looks like this type of hinge never had bushings. This is probably why Toyota went with the 3 ear style with bushings because the 2 ear were prone to wearing out.
As you can tell from both pictures, the bores are not big enough to install the later style bushings and it would not be cost effective to try and bore each hinge to except bushings.
Let me know your thoughts,
Solid pressed on one side, bushed on the other. To remove the pins completely you would have to press them out of one side.@White Stripe, are you thinking of the pins being removable or just that they are solid pressed in on one side and bushed on the other?
Yea so if u look at the above pic of mark's if he flipped the driver side hinge around then the driver and passenger side would capture the hood if bushings were installed.I emailed SMG to suggest this. It doesn’t help me sell Quik Hinges, but it serves a need that a lot of us want for better good hinges. Ask him.
Sorry about the plug for my stuff. Has some rum with mama...
if you do make some for the ambulance doors i will definitely buy a set for everything. just not quite ready on my project for them so i won’t rush in quite yet. love these ideas guys.
i bought a set of them all today. looking forward to getting them installed but that’ll likely be a year away or more the rate im moving. these should correct
my sloppy hinges though and that makes me happy!!
@White Stripe
I like your idea of pressing the pin in on the one side.
I will try this on Marks sample hinges.
Thanks
