Will Not Come Off
NEW JERSEY
Website
pg.photos.yahoo.com
I Have Tried Everything To Remove This And It Will Not Come Off. This Is The The Last Part I Need Off Before I Start Wire Wheeling The Inside Frame Rails.
I have not yet. next day of work I will have to go that route if nothing else works. It just makes no sense due to the fact that the bottom bolt came right off with no pb or anything the only thing that looks like it could be holding it in is the bushing and the washer. a mini sledge hammer did not move it. so idono
Use a bigger hammer! That's the passenger side bellhousing bracket. The head of the bolt often works it's way into the bracket to the point that you can't get a socket to grip the head any more. Often the hole in the 'saddle' it sits on gets oblong as well.
Screw the castle nut part way back on if you want to protect the threads on the bolt when you hit it. But seriously, you'll have to give it a whack upwards from the underside to budge it.
Prolly best to plan on buying a new bolt and castle nut anyways. Assuming you're keeping a 6 in there.
Best
Mark A.
Remove the bolt.
If you are going to take this frame in and get it sandblasted, what are you trying to gain by taking a wire wheel to the frame?
Remove the bolt.
the reason i am wire wheeling the frame is because the advise of you and other people on this forum. get to know you rig. i want to know every hole, bracket,mount,ect. on my frame. i want to check for any problem spots, or future problems so i can get ahead of any issue. If its at the sandblaster and he does not look or misses a problem. i do not have a problem down the road.
about the bolt, what do you think i was hitting the frame, come on........ use that brain God gave you, that is the common sense part of the brain in case you needed help figuring out that too!!!!!!!!!!!!!!!!!
Poser and 65SWB45 are tying help you. They are a wealth of knowledge, you seem to be getting frustrated with them when they are trying to help you.
Was 65SWB45 correct in not being able to get a socket on the bolt? Have you tried a torch to heat it up? What about an impact gun? Be prepared as you may snap it. What size ratchet are you using to take the bolt out. Have you tried something with a longer handle for more leverage?
As for the frame itself in your other thread I asked the same question why you are wire brushing the frame if you are sand blasting. You should be able to take a hammer and tap around it to see if there are any soft spots. Look for any cracks or if something is distorted. Wire brushing it is not needed in my opinion.
On my 71 when i did the sbc conversion I removed that bracket and it was a complete B****... I removed the bolts and no go but I cleaned it up with a grinder and wire wheel and apparrently the PO or maybe factory? tack welded it in a few spots. hard to see with all the dirt and rust on them.... may wanna check
The bolt may be stuck to the rubber bushing. Does the bushing turn when the bolt turns, or is the nut not even coming loose? I had no problem getting the nut off but the bolt was stuck to the bushing. A BFH or channle locks on the bushing and a wrench on the bolt. Same problem often occurs on bolts that go through the leaf springs and shocks.
If the bolt is stuck to the bushing it may help to tighten it more, causing the bushing to deform somewhat and maybe unstick.
I explained in the 6th thread about the bolt, i have tried everything. as far as Poser and 65SWB45 i know they are trying to help, and you are right the info they have is second to only a few. none of it was directed towards 65swb45, and i am not frustrated with Poser. he just comes across as a smart a**, and i am to, i did not take it personal and if he did, I would hope he would speak up and i would sell him, sorry, not personal just funin
sometimes hes a smartass i think lits of people are when they feel like someone hasnt tried everything they should have before they post. not saying that you havent treid.
i have no idea what im looking at in the pic. i would torch it , cut it, plasma it, saw it off.
Have you tried an impact wrench, or on the cheap side an impact screw driver? The later is available at most auto parts stores. They come with a couple flat head, and phillips bits, but they also have a 3/8 attachment. Very useful garage tool.
got it
tightened it as tight as it would go. then ground off the bolt and unscrewed it and it came off. thanks for all the good advice.
