so ive recently moved from california to washington. brought my FZJ80 up here. now im pretty sure my 80 isnt 100% waterproof(which isnt good in rain city) but for some reason the only place im getting water issues is the floor in front the passenger seat. i cant seem to diagnose where its entering at. its pretty much ruined my carpet. SO with that being said. i need help with some input as to where it might be getting wet from? if there are common spots to check?
also following that issue. i think if im going to have to most likely cut the carpet out now, i might at well do some sort of liner/coating inside instead of carpet because this will eventually turn into an off-road only rig anyways. what do you guys find works best? easy clean? insulating? sound dampening? etc. ive read monstaliner is a pretty solid choice for it. but what do you all suggest?
Search man, SEARCH! Even google wouldn likely lead you to a dozen threads on mud on this subject. Windshield gasket seems to leak in the corners. Sometimes sunroof drains get clogged, those are the most common issues. Unless it smells sweet then you may have a heater core issue. Or if you're running your AC to combat fogged windows the AC drain may be disconnected and leaking into the cab.
