GeoW5
can someone please tell me or show me with a pic where to find the date code on that one F engine head for an early FJ cruiser?, Thank you
Thank you!
Actually Classic Cruisers helped me decode using the stamped numbers on the left side of the block below the exhaust manifold towards the front. 5 for 1965, 01 for January, and 13th day of the month. Sounds plausible to me since my VIN breaks out to a January 1965 as well?View attachment 2057972
Not sure where you can reference the motor date code to. SOR only has it back to 1969.
Frequently Asked Questions About Your Land Cruiser - Specter Off-Road
Toyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...www.sor.com
I seem to recall a small pad with a date code stamped on the transfer case. Decoded the same way as the engine date code.
There's one on the carb also.
Thank you!Toyota Land Cruiser Transfer Case Identification - Land Cruiser Tech from IH8MUD.com
Toyota Land Cruiser Transfer Case Identification - Land Cruiser Tech from IH8MUD.comwww.ih8mud.com
the one on the transfer case is for year by a number. A letter for the month. The rear of the numbers are the number it was built that month. It does not tell you the day of the month. On the one piece case it's towards the back on the right side. There is a flat spot where it's stamped in. Split case have a couple possible locations but not where the one piece transfer case is stamped.
well then mine has 5A. so that supports January 1965!? So far so good on the drive train and frame. would love to find some body info...the one on the transfer case is for year by a number. A letter for the month. The rear of the numbers are the number it was built that month. It does not tell you the day of the month. On the one piece case it's towards the back on the right side. There is a flat spot where it's stamped in. Split case have a couple possible locations but not where the one piece transfer case is stamped.
