When to Replace Ignition Coil?
Dissent
Questioning my life choices...
GOLD Star
Sweetwater, TN (SW of Knoxville)
I've got a 97 LX with 200K. Last time the plugs were replaced was about 50K ago along with generic plug wires. I'm ordering plugs, cap, rotor and plug wires but I'm not sure if I should replace the coil. I typically replace the coil on my other cars when I do the plug wires.
Searching doesn't turn up much about replacing the coil which either says they are very long lasting or overlooked/ignored.
What say you all?
This might sound silly, but there's a reason...
Being that you're in AZ you're probably fine. The coil is an epoxy based units... in climates that have changing patters (seasonally and sometimes daily) can cause moisture to build up in an epoxy coil and cause them to fail (I've had this happen on a few toyotas, and never on an oil coil).
Either way - if you're concerned, look up in the FSM how to test the primary and secondary coil resistances, it's the same type of test for any coil.
What are the symptoms of a coil going bad but not dead yet?
I change them when they dont work any more. I live in maine and my 93 4runner has 350k +/- and its still on the original coil and igniter, hell its still on the original vafm, tps, ect, egr (although i did bypass it years ago) and pretty much every other sensor. Only one i know,of that has been changed is the o2, and that was done by toyota at 70k when they did the hg's under recall.
I've got a bit of a stumble and rough idle, figured it's a good time to replace plugs/wires but I'll test the coil using the FSM method and see what it says.
Will let you know when the first one dies! But it appears that you like to spend lots of needless $$$$ on your rig, so buy 2, install 1 and keep the other in the spares bag, just to have a piece of mind?! :hillbilly:
LOL, I'm trying to find a reason to NOT spend money, this rig is like a money sponge already!:flipoff2:
Thanks for clarifying guys, I'll wait until it dies.
BTW, I just picked up a Dodge Dakota for my boy and NONE of these rules apply to it. Quite a quality difference between the Toyota and Dodge!
I had the same problem last year and replaced cap rotor wires and plugs. - truck actually sounded better / smoother on startup. I also had a bit of a hesitation on acceleration. All gone with the tune up.
Lol... Dodge should not even be mentioned in the same post as toyota.
If ya want a decent dodge, ya gotta buy a early 80's or older, or a newer one with a cummins, and even with the cummins you'll still be throwing front end parts, and transmissions at it.
Cool. Glad to see its not an issue!
My old coil was shot, was out of spec per FSM, and was throwing an IGF failure/CEL. Just under 292k miles but who knows how long it was out, the previous owner removed the bulb for the CEL.
I'm not saying replace it just because, but I'm not also going to claim that a coil cannot fail. They can and do. After replacing IGF failure/CEL never returned.
Directly from my diagnostics:
Per the FSM, Primary coil (cold) should read 0.36-0.55 and the secondary coil (cold) should read 9.0-15.4k
The primary coil is reading 0.7 and the secondary is reading 11.66k
FSM states if either is outside of range, to replace it. So whether this is 'the' problem or just 'another' problem.... there is one found:
Your 0.7 ohm reading is bogus... You can *NOT* read such low values with a 2 wire multimeter. Just touch the two test lead ends together and you'll likely see 0.2 - 0.3 ohms give or take. That is the resistance of the leads, the connectors etc.
That's also a cheap meter and very cheap test leads in your picture.
It's "possible" to touch the test lead ends together, take the reading and deduct that from the actual reading - but accuracy is still quite poor at the low end of the resistance scale.
cheers,
george.
What meter would you recommend using? I have a pretty decent Fluke digital multimeter (circa 1995) and it's only 2 wire, albeit 3 hole, but it's served me quite well so far. I'm not familiar with a meter using more than 2 leads.
