- Joined
- Sep 17, 2003
- Threads
- 69
- Messages
- 4,677
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
It's not just the meter - it's the probes/test leads. ANY 2 wire meter (even fluke) will read a few 1/10ths of an ohm when you touch the ends of the probes together - it's just inherent with a 2 wire measurement. You would need to zero (if the meter has the capability) or deduct that reading from your actual measurement. You would also want more than 1 decimal in the display to look at sub 1 ohm readings.
The meter pictured above is also only displaying 1 decimal of precision on the 200 ohm range and usually a meter is also spec'd at +/- a couple of least significant digits (in addition to the measurement accuracy), so no way would I trust any measurement below several ohms on that one.
cheers,
george.
cheers,
george.
