16x8.5 - 315/75R16
16x8.5 - 315/75R16
Does the slee bumper have jack points on it? I like it
I’m wondering if you had to do anything special to get the center cap to fit or did it just go right on? I am looking to get the same wheels on my HDJ 81. ThanksNever pass up an opportunity to pic whore i guess. Black Rhino Warlords in gunmetal grey, 17x9 with -12mm offset wrapped in 315/75 Duratracs.
Seriously though, these what wheel threads all end up just saying "buy damn near any wheel you think looks good and has the right bolt pattern". Pretty much any manufacturer will supply you with the right centering rings for the hub.
Thanks a lot I appreciate it!Nothing, they just worked perfect. The front maybe wouldn't fit if they weren't -12mm offset though so keep that in mind.
Make sure to specify the hub centering rings when ordering. They are an odd adapter size that is hard to find elsewhere, so better to get them provided with the wheels.
16x8.5 - 315/75R16
That looks savage man. Thanks for the info I will look into those as well.Stealth Custom Series SR8 - 16x8 3.75" BS. These are almost a direct fit. There is a very small lip on the inside bore that is for the center cap. That lip needs to be sanded off. I did it myself in about an hour. Doesn't affect integrity of the wheel in any way.
View attachment 1607266 View attachment 1607268
Thanks for the photos! I love the look of those as well!Was this with your Heavy or Intermediate rears?
I dig those wheels and consider them for my FZJ80.Nothing, they just worked perfect. The front maybe wouldn't fit if they weren't -12mm offset though so keep that in mind.
When you say "The front maybe would't fit..." are you referring to the hub cover or the rim?
fyi after 6ish months these things take a beating.Ion 17x9 alloys View attachment 1454545
17x9 Pro Comp 97 Series steel wheels. They also make several 16in sizes. Cheap too
