nothing you have planned will be cheap ,almost every upgrade requires an upgrade drive it like it is and have fun .locker and a good winch would be a good start ,after you have a good chunk of change then go with other mods.good luck
why not just run it as it isat least for a while
wheel it some and learn what it can do, then you have a much better appreciation of what you really need![]()
Have a Bellevue winch as shown in the pics, after some cage mods and better seats, a locker will be next.nothing you have planned will be cheap ,almost every upgrade requires an upgrade drive it like it is and have fun .locker and a good winch would be a good start ,after you have a good chunk of change then go with other mods.good luck
, off-road I hit obstacles with the front shackles with about all approach angles.
i would run like hell and not get involed
On the last revision before being parted out ...
The shackles are from the PO,
tire pressure is usually at 8-10 lbs when off road,
Lift is the shackles from what I can see.
.Alright I am, have been thinking of what my FJ40 wants to be, or what I want it to be. It is a 1972 with a rear SR, front disc brakes, power steering, SBC, and sits on 33" A/Ts. First the facts, I have little cash to spend. What would you do, eventually I want 37" tires, SOA, a different roll bar that would include seat mounts. Really just looking for what would be smart and inexpensive to do at this time. I want it to be a 50/50, 50% on the road, 50% off the road. Please explain the pros and cons of the mod. Thanks.
Why does everybody hate the F series motors these days?
I'd take a strong 2F over anything Chebby any day.
"smart and inexpensive to do at this time"
SOA and 37s might be best tackled together--Im thinking this is well over your budget right now since just the tires will be a grand and wear out the ones you have first
The roll bar with seat mount and some bar mounted quality seat belts would make it look good, be practical from a safety perspective, and be close to your budget
maybe the smartest thing of all is banking it in case something blows like a gearbox or engine
BTW --pretty nice rig as is!
, second I will be waiting for the 33s to wear out before 37s are purchased and there will be a wait on the SOA until I have the cash or will slowly buy the parts as suggested. I have been thinking
it over and will be going for safety first, for sure. The tubing I purchased will allow for some armor and tube doors, place to mount the seats I purchased as well as a place to mount the harness when it is purchased. The safety harness will be purchased next. I know I cannot afford to do the bigger mods I want right now, but I would like to start with some of the inexpensive ones. Thanks for the advice, and about the F series motor, I would be fine if it was still in there, it was the PO decision to put the SBC in it. I am fine with that as well, it moves... and has the get up and go with just the slightest press on the gas.snip 8<
First the facts, I have little cash to spend. What would you do, snip 8< Thanks.
Yes I have the three speed.
I like the speed it crawls at in 1st low.
