What would you do with $30k
Las Cruces, NM
I’m planning of making a lifelong investment on my 78 FJ40, and would like to know and get other members perspective ideas.
My list:
LS33 5.3 (remove the SB 305)
EL60 transmission
FJ60 transfer case
Body/paint
Breaks
Power steering
AC
Expedition trailer
2016628
2016629
2016630
2016631
Maybe brakes instead of breaks?
Seriously though, that’s a lot to spend on that vehicle. I would buy a 96 or 97 80 series and spend $10k on paint and brakes for the 40.
Sounds like an ambitious plan, but if it is your dream ride and you can afford it...
Will you be doing some of the work yourself, or were you planning on having a shop do the majority?
Also, Matzell makes a good point
Put it in the gas tank and drive it around the country checking out cool places. Take the scenic route.
I strongly recommend you spend some time in Excel building out a detailed itemized budget before you start the project. It might take a long time to do it, but I think it will reveal the trade offs you are going to have to make. $30k is a lot of money, but believe it or not, you could easily spend all of it and still not check all of the items off of your list. That's why I recommend building a budget. And make sure you're as intellectually honest as possible while you go through it. And then add a 20% cushion on top for unforeseen stuff.
An LS swap could easily eat half of your budget, then you have sandblasting, sheet metal patching, body work, paint, weather stripping (def spend the money to get toyota original), wheels, tires, brakes, seats, etc... and there will be tons of little "while I'm in here, i might as well" parts.
And depending on the tools you own, you may need to make an investment in equipment. A sandblasting cabinet and a compressor powerful enough to power it have been a HUGE help with my project. I also repurposed a kitchen oven and got a powder coating gun- it's pretty nice to be able to blast and powder coat your own small parts.
I think you'll find that what others are saying here are true. You'll be better off selling your existing cruiser, and taking the proceeds plus your $30k of cash and buying a rig that's pretty much done. I'm willing to bet the person you buy that rig for will be taking a loss on it. :/
Good luck!!
Ok, I’ll buck the trend here- Do it yourself, it can be done.
Paint is a bugger, but if your going to use it then it shouldn’t be the best. Matter of fact, save the dough and refresh that beautiful patina. That just saved 3-6k. Do paint the roof though, that’s a no no.
Get a chebby that has the engine tranny you want with reasonable miles. 3-5k. Recoup what you can from what’s leftover, you might be able to pay for the misc adapter bits you’ll need, might.
Brakes and power steering- buy this. Swap the 60 axles and power steering in and grab the transfer case while you’re at it. This’ll solve the parking brake and give you a slightly wider stance. Sell what’s left along with the forty, put proceeds toward the chebby.
AC- no clue. I have snow on the ground 7 months a year. I’d pay good money living where you do to stay cool.
Tires $1200
Wheels- they seem to be skies the limit.
The trailer- sell it to me cheap, it’s only going to cause you heartache....
You’ll need tools- welder, cut off wheels(lots of them), plasma?, jacks, drill press....$5000 with prudent shopping, depending on what you have. Join the local club, might get some work done for a couple cases of beer.
Thank you for the input. I’ve had the vehicle for about 5 years and have been collecting a lot pieces. My 40 has a 700r4 transmission and axels have been re-geared. I will be doing most of the work myself. The paint will be done by a local shop.
If you choose the 700r or 4L60, you'll have a very limited space for a rear driveshaft unless you push the rear back
a decent amount. A short drive shaft means less wheel travel. Stock wheel travel is less than 8 inches overall so it's not
a terrible issue if you don't require high speed travel over rough roads. the front drive shaft gets terribly long so I prefer a
two piece with a carrier bearing. The plus side of that is the carrier bear requires a cross member right about the point that a
forward mount wound be needed for a trans pan skidplate
I'll go along with it can be done if one is cheap fiscally conservative like myself.
Somethings you can't cheap out on, engine rebuilds, but most others you can do for much less than the cost of "bolting on the newest stuff" There's nothing wrong with putting all new stuff, and thats usually what I would prefer, but sometimes budget doesn't allow.
Engine swaps are pricey and usually always end up costing more than originally planned. As others have mentioned, drivelines, mounts, extra cooling, wiring harness, etc.
That said, the brakes are low hanging fruit. Do the brakes, knuckle job if need be.
A few options and $$$ on power steering, not hard or terribly expensive.
A/C if you buy a kit I think is around $2k+ for the kit. You could get crafty to find bits here and there, but with A/C, I'd just go new.
Paint and body is dependant on what you want it to look like and how good. Your rig looks solid so I honestly would polish up that patina and roll with that.
Long ago as a defense contractor we could write cost plus contracts which covered all expenses and a profit. Every time I see one of these type threads they remind me why we wrote those type contracts, because you can lose your ass on a fixed fee contract.
