What to do about rust
Maine
This past weekend I was doing some maintenance on my 80. Finally got around to routing some wires out for the light bar on my ARB. I ran the wires through the grommet in the drivers side firewall.
What I noticed was bad. Removed the carpet and matting on the interior and found a LOT of rust. Covered in rust from the center console area, all the way to the fuse box, and under the carpet back to the drivers seat. It is all surface rust on the metal there aren't any holes and it's not pitted or anything.
My question is what the heck do I do about it? Should I paint over it with one of the epoxy based paints? Sand it first, prime it, paint it? I'm afraid to look at the passenger side where I know I have a leak from the windshield being put in wrong.
http://www.homedepot.com/p/Loctite-16-fl-oz-Naval-Jelly-Rust-Dissolver-Bottle-553472/203009241
It's very cheap and very effective (and also at wal-mart). It's mostly phosphoric acid, so while it isn't dangerous, I would work in a well-ventilated area and keep it off your skin. It's safe (afaik) for the environment if you just wash it down the drain. As for what to do about it afterwards, we have every intention of bedlining our interior - however, we're divers and our 80 isn't meant to be comfortable or a DD. So that may not work for your application.
Most all the rust remover brands are phosphoric acid. Any will be great. Use it, do a little clean up and paint over it for an oxygen barrier to stop future rust. The phosphoric acid works on the iron in the floorpan to make iron phosphate, a kind of cold plating - becomes it's own primer for your paint. Good luck
You can also cover your dash be other remaining interior, buy a sanding brush used for AL's liner and use a good drill to quickly remove the rust, then wipe down with OSPHO and towels, follow that with some etch primer and your choice of paint over the top. Just remember that primer's etch or otherwise will not prevent future rust. If you can't find OSPHO locally then you can just use rust reformer. Your primers and rust reformer can be found in the same isle at Walmart.
Also from Maine; I keep a can handy anytime I do maintenance and shoot anything I see that even looks like rust. It's a $1.00 cheaper at Tractor Supply if you have one near you.
Yah buddy, ain't the rust belt just dandy? I have tried a couple different kinds of rust remover and haven't found anything that works as well as mechanical removal, either wire brushing or sanding or sandblasting. Stuff that is small enough to put in a bucket or drum can be electrolytic-ally cleaned, all you need is a battery charger and some washing soda, there's lots of info to be googled on it. Just be sure to put a good coating of paint over your bare metal because that damn rust just keeps coming otherwise.
And Fluid Film is your friend up heah, or at least it should be. For getting rusted stuff apart, a 50/50 mix of acetone and transmission fluid is awesome and cheap. Hope this helps.
