Yeah, they weren’t cheap. Five of them cost me $1800.i haz the Geo M/T lt255/75r17s.... Paid $210/tire in 2021...now $287/tire ooooof
35s for me would involve an H55 and t-case gears with lower low & high range. I have 4.11s in the diffs already. I've typed the math into online gear calculators 100 times at this point and keep scheming. Final ratio in first gear would be lower than what I currently have, gears 2/3/4 would be nearly identical, and of course I'd add the overdrive 5th gear. The underdriven t-case gears essentially take me from 4.11 to about 4.75 in high range.Both my 60 and my 40 are on 35-12.50 X 15 Mickey Thompson tires, have been for many years now. I didn't notice a huge difference is sidewall flex or excessive body roll after install on the 60. I still run about 35psi on road and 18-25 psi offroad. On road behavior is not that much different for me. OffRoad there is a large difference in clearance. Trail obstructions are easier because of the circumference difference. On paper it doesn't seem like much but real world seat of your pants its fairly obvious.
One thing to keep in mind is both of my rigs are swapped with fairly healthy V8's. Your Mighty 2F would feel a lack of power unless you re-gear it to say 4/88 to get back to stock type runout.
That would be a great alternative Jim. Better low range is always better with the way you use your 60.35s for me would involve an H55 and t-case gears with lower low & high range. I have 4.11s in the diffs already. I've typed the math into online gear calculators 100 times at this point and keep scheming. Final ratio in first gear would be lower than what I currently have, gears 2/3/4 would be nearly identical, and of course I'd add the overdrive 5th gear. The underdriven t-case gears essentially take me from 4.11 to about 4.75 in high range.
@HemiAlex I'm over here making plans.
You’ll get your gift soon.35s for me would involve an H55 and t-case gears with lower low & high range. I have 4.11s in the diffs already. I've typed the math into online gear calculators 100 times at this point and keep scheming. Final ratio in first gear would be lower than what I currently have, gears 2/3/4 would be nearly identical, and of course I'd add the overdrive 5th gear. The underdriven t-case gears essentially take me from 4.11 to about 4.75 in high range.
$1107 for 5 in '21. #NutsYeah, they weren’t cheap. Five of them cost me $1800.
Coming up next week! Don’t get a ticket!Stop by anytime! Shoot me a text. s*** that reminds me I need to bleed the clutch onn the 40 so I can move it for street sweeping day!
Just an update: For anyone with a 62 series, the speedometer is about dead-nuts accurate with 255/85-R16 tires and 4.88 gears. 60 MPH indicated is 59 GPS.
For a 60, if you wanted 255/85-R16 and retain the effective "stock" gearing, you'd need to go from 3.73 to 4.56 gears. Your speedometer will probably read about 4-5% high however.
I've got dual voltmeters, air:fuel gauge, water temp, and vac gauges tooSame, on my tires I’m about 5% lower on the speedo, so 55 is 60 and I have no problem doing some quick math while shifting, watching the water temp, voltage, the phone, shifting, figuring out the true speed, looking at the rear view mirror, side mirrors, shifting, watching the gauges—I FEEL SO AWAKE!!!!
