what headers to buy?
Texas
Is the Man-a-fre ceramic ones the best to go with?
They are the best ones that I have used or installed, hands down.
:beer:
I just installed the SOR two-piece headers. So far, I'm very satisfied wit the mid-range power increase and the quietness of them. I would highly recommend them to anyone. I ran the 6 into 1 header system before. That header cracked about a month and a half before I put on the new system.
Two piece MAF ceramic fit nicely. If you don't go MAF at least make sure you get a two piece as it will help with those pesky intake leaks.
I'm using the SOR headers with the complete bolt on exhaust system.No problems at all.I'm going to order the MAF headers today with the complete bolt on system for the new motor.
actually I ran the one piece old school headers on my 2F for years with no problems, you really need to mill the intake and the header to match flange thicknesses though, I also ran double gaskets. I am surprised how much more the 2 pc headers are. I think I will just use the older style and use some standard pre bent pipe to do my exhaust. Save myself quite a bit of $$.
noah
2 cents
The 2 pc. will not fit with stock steering box so anything that takes up the same real estate will be the same, I went with the one piece and an offy that has the same flange thickness, might double gasket as well. I High temp teflon coated the header and wrapped it with copper headr wrap too, try to keep heat away from the intake.
Poser,
it looks like you had to take some material off that intake though, did you?
Nope.
F engine intake on an 1982 2F with step-down studs...
I had to cut washers in half to make spacers for the different thicknesses of the intake to header mounting flange....no big deal.
Poser, are you using two gaskets here?
One SOR header gasket with ultra-black around each hole, both sides of gasket...
Did that on the first set of two piece SOR headers that I installed back in 1989 and have done the same thing on every set of headers that I have installed since, including these MAF headers. Works great, no leaks.
:beer:
What do you mean? I'm running the SOR 2 peice header with stock everything. The reason I chose SOR's is because they guaranteed it would work with my column shift setup. Since I had to have them shipped to me, I didn't want to waste time with something that wouldn't work or would take a lot of messing around with. SOR's header worked great.
The 2 pc. will not fit with stock steering box so anything that takes up the same real estate will be the same...
I don't know bud....
I installed a set of the MAF two piece headers into a 1978 40 series with a stock-style power steering conversion and they work fine...( I will try and get some pictures of this Friday and post them here, as the truck is at the shop )
I installed a set of the MAF two piece headers into a 1975 40 series with stock manual steering and they work fine...
I installed the SOR two piece headers into my 1969 Red truck back in 1989 when it had manual steering yet, and they worked fine...
:beer:
:beer:
I installed the MAF two piece into my '78 with a mini truck power steering conversion (pump bracket mounted to the two headbolts). I also have all the factory emissions. There is plenty of clearance for all the components.
