I finally got to power up the DD. Check out the reflection in the new column cover.
how i dream of a dakota digital gauge....
I obviously do not understand how to do pics on this site, sorry..Installed marine/ATV remote control, Bluetooth speaker system under the seats. Will control with iPad mini4. Fear not, purists--it was a chopped up, rust bucket, bondomobile before I started. Now a restomod BJ40 island hopper in the Philippines. Native Texan retired to the islands.
Hey, I need one of those shirts! Being a mere "affiliate" member since I'm from TN, can I still grovel enough to buy one?Yesterday I installed the weather stripping on the drivers door, the tunnel cover and heater box.
I also picked up my new club t shirt yesterday that nearly matches the color of my 45.
View attachment 1382662 View attachment 1382663 View attachment 1382664 View attachment 1382666
Hmmm, didn't know they were so close (tranny humps). I need to keep an eye out for a 60 hump as my 40 hump search has not been fruitful.@Jdc1 Actually it is the entire tunnel cover from a 60.
Been chasing front 'wheel bearing play' for some time - which in the end (should've known) turned out to be worn stub axles allowing the outer bearing cones to move around, as evidenced by the neat groove in the left and right side spacer washers. Both outer bearing seats were quite worn and certainly didn't pass the fingernail test. Probably not helped by the extra weight of the 12HT and neg 22 offset rims.
The strip down also revealed that a full knuckle and wheel bearing overhaul was due when a water/grease mix ran out of the hub after just too many river crossings. I also don't remember the front diff oil being coffee colored when I put it in. And because I can ... I thought while I'm at it I'll treat the 40 to some new black steelies and 31" KM2's, along with 3 deg caster wedges to finally allow me to relax a bit while trying to drive in a straight line! Much less twitchy now.
