I really appreciate your input, Mark!!
At the risk of sounding like a skinflint customer, I'm not so concerned with the the rear tires smacking the fenders, because I have BOSS air bags on the back... they took the place of the rear bump stops... right now, they only have 15 psi...
I would, at least, double that when going off-road... I adjust my bags up, when I air my tires down... I adjust my bags down, when I air my tires up... (I also brush my dogs when I air back up... that keeps the yelling to a minimum when we come in the door).
I made that rule to allow me to be sure I don't take the garage door header out because 44 is too high... and to keep Dianna's dander down. Exception: When leaving on a road trip, I adjust the bags up or down, based on how much gas I have in the aux tank.
It would have taken about 80psi to hit the header with the old tires... it will take about 40-50psi now... I haven't had time to suss it out yet.
Regarding the drift... 44 was terribly dangerous when I bought her... she drifted worse than a sleep-walking drunk with vertigo... the tie and relay rods wouldn't allow me to adjust the toe-in properly. CDan sourced me new rods and TREs... the rods were threaded 1/4" more... I only needed an additional 1/8" to make it perfect.
The drift I referred to earlier, is associated with roads that have grooves to prevent slippery-when-wet... she doesn't drift from lane to lane, like she did when I bought her... just slightly to left and right... not frighteningly and only on those 'grooved' roads... and, again, I'm not sure it's worse than it was, on those roads, but I'll find out when I have more time to drive her.
I originally debated 16" vs 15" rims... then 7" vs 8"... it ultimately came down to my desire to NOT have to run a spacer... the 15x8s were the only 'cheap' wheels I could find that had the correct bolt-pattern, with 3.50" backspace. In this environment, I've never aired down below 15psi... I doubt I will go that low with these KM2s... more likely 18psi or so.
I really like the way the tires and rims look on 44... but, I want to be safe...
Do you feel I need extended bump stops on the front?
Do you have any other concerns I should keep in mind?
Thanks!!
Thanks!!
