Most seem to crack like this one:Is that crack location the most common spot? I have a tick as well but haven’t seen anything on the manifold itself so not sure if it’s a crack or something entirely different
Congrats on fixing the AC, bet it feels great!Finally buckled down and bought myself a vacuum pump and some HVAC gauges, and got the 100 AC going again. System had leaked down from a really tiny pinhole where the high pressure line over the radiator, right where the rubber hose transitions to the hard pipe.
Mainly, easy work, but I had been going "ehhhhh do I WANT to spend $200 on tools for this or just pay the shop," finally decided it was just getting toward "mean" instead of "character building" for the kids when they drive it around. I work from the house, so it could stay like that for me a long, long time. Kids are less forgiving. Blowing cold air, not leaking, we're set. Feels good.
How did you identify that as the leak location? I am starting down some investigation on my AC.Finally buckled down and bought myself a vacuum pump and some HVAC gauges, and got the 100 AC going again. System had leaked down from a really tiny pinhole where the high pressure line over the radiator, right where the rubber hose transitions to the hard pipe.
You can get UV dye either as a standalone item or as part of a recharge bottle of R-134. Then you shine along with a blacklight (Autozone, $10 or so) until you see a green glowing area.How did you identify that as the leak location? I am starting down some investigation on my AC.
My 2003 LC100 was originally automatic, I just converted it to a H151 5 speed manual, was a seamless conversion. I also got rid of the AWD transfer case (4HI, N L4) where you had to lock the center diff with the button and made the switch to the 1998-2002 part time transfer case (2WD, 4HI, N, L4). I plan on wielding the rear differential as well open diff gives too much understeer during sand dune crests, with the open diff I have to rely on loading and unloading with the throttle to keep it straight with excessive steering.
Had a blast testing it in the sand dunes.
The only mods from stock are:
Exhaust: 4-2-1 long tube headers with 3 inch downpipes catless and a straight through mid muffler and 3 inch tail pipe resonator.
Cold air intake, the classic K & N one.
The 2UZ-FE is spectacular for a stock engine on stock ECU to perform this well, thing glides through the dunes, all this in 45c ambient summer temps. Cant wait to switch to a standalone ECU, ill go with a Maxxecu Race GEN 2 with dual LSU 5.2 lambda.
Is this one of those after Market whale tails?For the whale-tail folks... Test fitting the chaselight replacement for the 3rd brake light!
Nah, this one is Toyota. Just from a different truck.Is this one of those after Market whale tails?
Nothing, check engine light has been on since 2011 with many DTC codes so the swap just added to it, never affected operation.What did you do for the ECU throwing the transmission codes?
Nice! I've gotta do the same thing with my floppy paint stained tailgate too!Starting to prep for the new drawer build, and decided it was finally time to trash 12 years of bacon grease, dab stains, and muddy dog prints. 1/2" Baltic Birch, with Varathane Gunstock, which is pretty damn close to the LX woodgrain- just a hair lighter. I'll throw the first coat of poly on it later today, then sand with 400 grit tomorrow and add a second coat of poly, then wet sand it with 1000 grit on Friday.
Finally knocked a bunch of little upgrades off my list.
New steering wheel cover from Amazon/Loncky (it was a super tight fit - I wound up needing to trim some of the original leather off the spokes and use some heat the stretch the leather ... the end result being it's now a little loose in spots on the back side of the spokes, but the seams are all closed).
And finally got my Artisan Garage under-seat-bracket and rear D-pillar brackets installed. I painted everything with Glidden Max-Flex tan spray paint which matches the original interior pretty well. Still need to finalize what's going on them, but I've got the essentials.
And lastly, installed some nice tinted window visors from WELLvisors for that JDM look.
