50-50 harbor freight yellow degreaser and water solution in a spray bottle, a detailing brush and this to refresh the plastic and rubber components without the greasy and tacky finish.what did you use?
Regarding the broken bolt… you’ve gotta fix that. Eventually, the bushing retainer will deflect and cause more problems. Probably sooner rather than later.front and rear bushings, doesn’t ride like a boat now, wish I did this sooner. Also did front rotors pads and bearings which was a new experience. Snapped one bolt off, no luck trying to extract it. View attachment 4159462
Earlier this month, my mechanic replaced my 26-year-old leaky rack and pinion with a new remanufactured OEM R&P. While he was in there, the outer tie-rod ends were replaced with 555 units, and the R&P bushing was replaced with an OEM unit. Truck drives like it's new... for the most part. I still need to refresh the rest of the suspension and get my hands on some new front upper- and lower-control arm bushings. Can't wait for my lift kit and sliders to come in so that those can be installed too.
As for what I did this week, I installed an OEM 1997 Camry/ES300 Charcoal Canister to replace the OEM one, as the Land Cruiser and 1st Gen Tundra Charcoal Canisters are no longer in production.
I tried extracting it. Wouldn’t budge, wasn’t even rusty. I ended up drilling it all the way through and still the threads remained, reamed it a bit. I put a bolt and nut on. I may go back and tap it one size up, but will this suffice?Regarding the broken bolt… you’ve gotta fix that. Eventually, the bushing retainer will deflect and cause more problems. Probably sooner rather than later.
I have had great success by drilling out the exact center of the broken bolt remnants… center punch the exact center… using a full drill index, start small, and continue stepping up the size of the drill until you reach the drill size recommended for tapping the hole. Then try a broken bit extractor… and/ or left hand drill bits…
I use Rapid Tap fluid for drilling and tapping, and lots of PB blaster to penetrate and loosen up corroded bolts. Maybe even run the broken bolt all the way through, if the back of the bolt is covered in corrosion.
After extracting the broken bit, run the appropriate tap through to clean up the threads in the captive nut. Then the new bolt should thread in without issue.
New bolt is Toyota Part # 90119-08B50
$2 each at Toyota Online Parts Center.
That will suffice. As long as both ends of the bushing retainer are bolted…I tried extracting it. Wouldn’t budge, wasn’t even rusty. I ended up drilling it all the way through and still the threads remained, reamed it a bit. I put a bolt and nut on. I may go back and tap it one size up, but will this suffice?
Is that crack location the most common spot? I have a tick as well but haven’t seen anything on the manifold itself so not sure if it’s a crack or something entirely differentReplaced the passenger exhaust manifold after hearing a tick for a few weeks.
I’m pretty sure that’s where a lot of cracks appear. I couldn’t see anything when it was on either.Is that crack location the most common spot? I have a tick as well but haven’t seen anything on the manifold itself so not sure if it’s a crack or something entirely different
Forgot to mention I’m using a @LJE fuse box mounting bracket for the switch and fuse blockView attachment 4158068View attachment 4158065View attachment 4158063View attachment 4158064View attachment 4158061
First time using the roof box on the 100 and just got a full set of sunshades from heatshieldstore.com
These brackets are now laser cut right here at LJE HQ!Forgot to mention I’m using a @LJE fuse box mounting bracket for the switch and fuse block
The Artisan Garage — Handcrafted Auto Parts Marketplace
Shop custom-built parts and accessories from verified artisan makers. Direct-fit, handmade quality for cars, trucks, motorcycles, boats, ATVs & more.theartisangarage.com
@LJE Product idea! Winch control box relocation bracket. I repurposed a Slee dual battery tray BCDC mount but might change it up to get more airflow.These brackets are now laser cut right here at LJE HQ!
(that's right, freakin' laser beams!)
Ended up doing a m8 helicoil. First time doing this, i went a little too far past and had to cut the tab. It was a bit of a struggle threading the bolt in after that. I’m afraid to remove the bolt now.That will suffice. As long as both ends of the bushing retainer are bolted…
Is the new bolt and nut, that you installed, smaller diameter than the M8x1.25 pitch original bolt? SAE bolt or M6? Would be good to have an OEM M8 bolt in that position for the benefit of better corrosion protection offered by the OEM bolts. If this strategy fails, 4 series stainless steel bolt and nut will suffice. 4 series stainless is stronger than 3 series.
You were able to pass a drill bit through the remnants of the old bolt… if you used a 6.9mm, or 17/64 drill bit ( the correct size for M8x1.25 tap), you may be able to get a standard M8x1.25 tap to start and cut clean threads through… use plenty of Rapid Tap fluid. Or the Rapid Tap paste. Clean with brake cleaner after tapping to remove milling debris. Then copper coat on the bolt threads.
A bottoming tap probably won’t work, but a standard tap with tapered lead end should do the trick. Go slow and keep working it a little at a time. Just like tapping threads into a steel blank. Bolts are hard, but taps are much harder on the Rockwell scale.
Just my thoughts…
I had a crack in mine as well with the tick sound, ran me about 1700 at a shop.I’m pretty sure that’s where a lot of cracks appear. I couldn’t see anything when it was on either.
Over the last 2 weeks I replaced every suspension and steering component and bushings front to back, all OEM - and my 1999 drives like a dreamy floating land yacht. Just how I like it, gliding over bumps and potholes. More relaxing drive for sure. Big pile of work but so worth it.Earlier this month, my mechanic replaced my 26-year-old leaky rack and pinion with a new remanufactured OEM R&P. While he was in there, the outer tie-rod ends were replaced with 555 units, and the R&P bushing was replaced with an OEM unit. Truck drives like it's new... for the most part. I still need to refresh the rest of the suspension and get my hands on some new front upper- and lower-control arm bushings. Can't wait for my lift kit and sliders to come in so that those can be installed too.
As for what I did this week, I installed an OEM 1997 Camry/ES300 Charcoal Canister to replace the OEM one, as the Land Cruiser and 1st Gen Tundra Charcoal Canisters are no longer in production. View attachment 4159064
