This happened. And the light on ”D” doesn’t work. That’s about 345k miles.
^ The "D" light delete is my favorite mod.
I would argue this haha. After 5 years I finally fixed mine. There was a brief moment where it randomly started working again and it was kinda nice.
Not mine, no connection to that person, just posting for California Bay Area:
Could help out locally if needed.
Picked up this 100% rust free 2006. Drove it 900 miles back to Colorado and got 16-17mpg at 70-80mph. Pleased with that, but it won't last long. Now have to prep my FZJ80 for sale before I can touch this.
laaawd have mercy, CVs have been on my list for a while. I'm really dreading it. I've seen some YT videos where they just take the castle nut off the upper ball joint and drop the whole hub assembly down, giving access to the CV. Does that actually work in your experience?
Feels good to check the box on the list of some of the things that have been nagging me for months.
Have had intermittent weeping from my CVs for the last two years and put new bands on them last year, hoping that would fix it but last couple of months the grease was getting slung everywhere. I will keep the old ones as spares and use the re-boot kit from @cruiserpatch . Plus, two thumbs up on the seal tool he sells. Made the installation idiot proof.
Finally decided to do it yesterday and the first one on the left-hand side took four times as long as the one on the right, as I learned from my mistakes. So glad it’s done now.
That Ironman suspension I put on last year has a fatter shock body than the old AHC shock and the sway bar link and had a helluva time getting that first axle out and new one in. Ended up unbolting the lower bolt and was able to get the axle in and out much easier.
Did find both the upper ball joint boots torn so now I will be replacing those as soon as I get the parts.
View attachment 3893224View attachment 3893225View attachment 3893226
Needed a 1 banana job, so I picked up the 4 door sill weather stripping parts, as well as the rear door seals. The left driver side door seal was sagging and would occasionally get caught in the door frame when closing the door, so I just went ahead and did both sides. The door sills look much better than the old, weather worn and sun-beaten ones.
It's really not that bad depending on rust. Make sure you have a prybar and might as well get some new boots and grease for the upper joint. It's 3-4 Banana job, just time consuming. You'll be fine, are you replacing or rebooting CV's? Reboot is way more of a PAIN IN THE A#$
Yes, it works. It’s a bit of a puzzle to get the ends where they belong, but it definitely works.
Used this method a couple weekends ago and it worked well. It helps to have an extra set of hands when installing the new ones. Took about 3 hours total. Made a big difference in the drivability, no more "clunk" when shifting between P-R-D. For disassembly, with the drive flange/circlip still in place, you can use the UCA as a lever to remove the old CV's. A couple of brisk pulls and they dislodged easily. A bit daunting at first but not as difficult as I had anticipated. 250k on the original set.
Thanks, yeah I'm just replacing. Not going to bother rebooting old CVs once I've committed to getting in there. Rebooting the upper ball joints you mean? had not considered that.
Thanks for that. I went ahead and picked them up and I'll try this either next weekend or the following, depending when the CVs show up.
Side question. Do I need to replace any fluid in the front diff after doing this? I don't have any leaks, so I'm assuming whatever seal is in place there can stay, or do folks normally replace those too (on the diff side)?
If you jack up one side at a time you won’t lose any oil. It’s a good idea to have the diff seals available. Not a bad idea to replace them, but if you don’t have the seal, the chances of boogering it up go up exponentially.
Think I narrowed down the god awful speaking noise in my front end to a bad lower ball joint which is super disappointing because I didn't replace it too long ago with a 555 one and it only got bad after a trip to the coast.
