What have you been doing with your Toyota?
Took it out for a drive to get it hot and mix up the oil. The timing needs some adjustment. Not a huge deal. The oil change though... Yikes.
I'll need to do another oil change to get all the contaminated oil out. I'm glad I drove it before the change to make sure it was in solution, but it sure made it look bad!
it might have been a good idea to drain a bit of the stuff out of the pan before running, until it was oil versus water/coolant, as water will sink to the bottom, then it wouldn't have gotten mixed with the oil and thru out the engine. then run and do a drain and fill.
You're likely right, but I assumed it was already everywhere since it came in through the top. I suspect it'll clear up with one more oil change.
Might be a good idea to drop the oil pan and inspect the main and rod bearings in case there’s any damage from the coolant. When I purchased my 80, coolant had mixed in the oil, a rod bearing seized and it threw a rod through the oil pan.
replaced a fuel pump in a 62 series many months ago, filled the tank up and had a leak, thought it was the seam, a bar of soap didn't fix it.
finally decided to drop the tank and found this area with a small crack. cleaned it up with a flapper wheel
it is on the left side, upper part
not sure how I could have done it during the pump swap.
good thing I had an extra tank from another 62
put it in place and all is good now
Rebuilt all but one wheel cylinder for the FJ55. Boogered up a part and now I need to repair it before knocking the last one out.
That bench looks like a real treat to work on!
Finally started the front end rebuild on the 80. It’s taking longer than expected but I think the knuckles had been leaking longe than I thought so the cleaning process has been a nightmare. Passenger side is done and I’m hoping to finish up the driver side in the next couple days. Also doesn’t help that I was only able to work on it during kid nap times and after they went to bed for the night.
Hey Paul, what’s the soap in the seam trick? Looking for bubbles? Liquid soap?
old, old school, use a bar of soap and rub it in the leak and it stops it, like magic. and it'll last a long time like that, nothing else needed.
That’s nuts! Never heard of thank me before.
I got the timing adjusted to 12 degrees before TDC, but now I'm having tuning problems with the Edelbrock carb. (What a shocker.) I've got a vacuum gauge ordered that should be here on Tuesday. I also replaced the taillights with LED units. I need to get some resistors to get the flashers to work correctly. Those should show up Tuesday as well.
I have a pair of resistors if you need them sooner.
I hate throwing away cruiser parts but this one is going in the trash unless it can help someone out. Free to a good home.
Got the vacuum gauge hooked up and tried to do some tuning. Mostly just confused myself. Once I started ignoring the gauge, I got it running sort of okay. It was hot outside and my daughter was "helping" so I didn't end up taking it on a test drive. Maybe later tonight, if it cools down at all. Maybe I'll "test drive" it over to @elkun1 house and ask for some help.
Upgraded to 33’s.
After the last club event we were at it needed to happen lol.
