What has left you stranded?
Perhaps the most outstanding thing I noticed about this thread so far is the lack of patterns or repetitive issues and most of what I read here could have been averted with better routine maintenance and attention to detail by the owner. I’d be willing to bet that the occurrence of cruiser stopping issues becomes nearly nonexistent once an ocd mud member owns the vehicle for long enough to iron out the wrinkles left behind by previous owners.
This is an interesting line of thought. I've owned a whole lotta toyotas going back to the 90's. Some notable failures were snapped leaf springs, radiator fan getting into a fight with the shroud, driveshaft getting in a fight with a rock, driveshaft getting in a fight with the exhaust, exhaust getting in a fight with a rock, starter failure (can always whack it with an axe handle to get it going), battery failure, melted wires, ripped apart maf wires, intercooler piping coming apart, massive oil ingestion, massive oil ejection, power steering fluid geyser.....
Only "stranded" twice:
head gasket in my '87 supra turbo
carb clogged up with chunks of rubber after I tried to cheat emissions by running e85 in my fj60
Well, three times if you count the rollover, but technically the truck still ran fine. :hillbilly:
Are toyotas reliable? Absolutely. Are they some of the most reliable vehicles ever made? Probably. Are they still machines made by humans? Yes.
People seem to forget this. You can have the best design and all the most current PM in the world and still experience a rare failure. Thats just the way it is.
Agree completely.
Aftermarket alarm system tied in to the ignition shorted out and shut me down, had to have it towed. 5 crank bearings spun and destroyed the shaft after running out of oil (user error).
that's a pretty accurate statement, and some of the things that were neglected by the po wasn't noticed till it caused an issue.
or we did dumb stuff all by ourselves, I forget that the starter went out after I got stuck in a water hole. didn't sink the truck but had to walk out on the hood to keep from getting wet and throw the tow strap
Happened to my daughter multiple times and the reason I found IH8MUD. Leaving a friend's house it wouldn't start. Just nothing. So I pulled the battery and went to auto parts store. Battery tested good. Put battery back in and it started right up. Strange. No issues for several weeks. Leaving work, wouldn't start. Told her to try "jiggling" the wires connected to the battery. Started right up. Then she knew how to "fix" it. Did this for awhile unbeknownst to me. When I found out how often it was happening I started researching and learned about the fusible link. Another issue, I got a call asking if smoke was supposed to be coming from under the hood. Not much, but some. I asked if it was smoke or steam. Well, it could be steam. Can you tell where it's coming from? From under the hood. So I asked where are you? Driving down whatever road it was. Well STOP. So about 5-6 gallon jugs of water and a slow crawl to a shop stopping to refill the radiator every 5 minutes later I learned about the PHH. Still on original HG though.
Agree completely.
Yeah, these are reliable and MAINTENANCE would resolve most.
Not like Ford 4.6L that randomly blow spark plugs out of the hole or the other V8 that the plug breaks off in the hole or the lug nuts weld themselves to the studs and have to be surgically removed by a dealership.
Toyota doesn't have those kinds of piss poor engineering f'ups.
The 1fz like most modern petrol (and more recently diesels are in that bucket too) has a lot of electrics/electronics that are essential for the vehicle to start and run. Fuel injectors, electric fuel pump, ECU, lots and lots of wires, lots of sensors, lots of stuff to worry about. Our 80 never stranded us, but an injector did fail open circuit within a mile of our home and we just babied it back to the driveway. These kind of electrical failures give little or no warning - one day working, another day dead. I did have the heater valve self destruct on a sand dune, but had some spare hose in the tool box and quickly bypassed the valve before it spewed all the coolant out. The 80 has way too many little coolant hoses running this way and that - but that's a modern vehicle syndrome too.
As much as I like the 1fz 80, I still treat it with some level of mistrust, especially if getting miles from rescue. My mistrust is not mechanical, it's my concern about all the electrical/electronic bits.
Now, my old 1980 patrol in oz, diesel and all mechanical (even gear timing). I NEVER EVER worry about it not starting or having some operational issue while out bush. Just returned from 3 1/2 weeks in the remote outback with my son, and the old patrol was rock solid reliable. I claim it is "too dumb to break" :)
Of course the other being stranded issue is user accentuated breakage and often is testosterone induced :)
cheers,
george.
Never been stranded but a situation that wasn’t fun was being on a 400 mile road trip and a water bypass hose cracking. I limped it home by continually adding distilled water to my nice new coolant. Just spent more money getting all new hoses from wits end - its about time to replace every piece of rubber underneath the hood.
Only ever been stranded once....due to a failed rod bearing at 265k and a hard life. Still ran, could probably have driven it for a while but got a tow to try and minimize further damage. Otherwise nothing has ever failed in a catastrophic way to actually leave me stranded.
Yeah I agree my issue couod have been averted by routine maintenance. I had been replacing/servicing a lot of things prior to the phh going out and was just waiting for a warmer weekend to get it done since it happened during winter.
Total loss of power about a block and half from home - wiring harness had been chewed up by mice and needed full replacement.
My 91 has left me stranded 2 times. Both times were cooling related. First time was when my stock radiator took a crap @ 220k up in Zion National park. 2nd time was on my way back from Big Sur, one of the smaller coolant hoses from the WP blew on the highway. Other than that, it has been dead reliable
So have you had the hands on joy of actually dealing with this problem? Better yet, have you had the pleasure of dealing with a broken off spark plug tip in a 4.6? If you haven't, I can tell you from first hand experience that removing the broken tip from a spark plug on a 4.6 is a BIG pain in the ass. After dealing with crap like that the pain i get in my back while changing the PHH on a Land Cruiser seems like a walk in the park!
I got water on top of my engine and it was telling me that I had a misfire. So I parked it with the hood facing the sun and just chilled for a while. Eventually the water went away. I checked the tightness of my spark plugs and boots....then drove home.
That's the only time, if that even counts.
I've had my Cruiser for 19 yrs...this year. NOT ONCE in 310K miles has it left me stranded. Came close....one time when the top of the radiator (plastic) split and the coolant started spraying out...but I less than a mile from home....and made it just in time.
I've replaced the starter contacts exactly once, but even then...the engine started, just clicked a few times before doing so.
Still on the original drive train...right down to the U-joints. Has the original head-gasket, water pump, power steering pump, alternator. Replaced the Brake Booster, but that was a soft fail (gave me warning) and was able to drive it.
I just basically replace the 'wear parts' as they begin to give trouble and she just keeps on going. Never been 'stranded' or even close to not being able to make it home.
Maybe I'm lucky? Or maybe Cdan just let me 'slide' all these years. ;)
Not personally. Cousin's truck, friends truck, and co-worker truck.
Ford sucks.
Failed fuel pump resistor once left me stranded temporarily, once I figured it out a paper clip got me home.
It’s not just the 4.6, btw. I had a Triton V10 that used its plugs as bottlerockets too. 🙄
