What hard tops do I have?
Houston, TX
I need to replace glass in one of my side panels, when I noticed differences in the two sets I have. So I guess I’m going to have trouble tracking down weatherstripping? Notice the window in the red panel is recessed in, unlike the green one. A couple of other minor differences as well.
The recessed one is 6/71 and older. You can see the slot in the weatherstripping where the key goes. The other is 7/71-8/76.
I may yet have one or two NOS weatherstrips for those on the shelf. If you VM me, can check tomorrow.
Thanks for that info, I’m hoping to save the rubber when I remove the glass to restore these but I don’t see how I can remove it without wrecking it. I’ll call you tomorrow, thanks
@65swb45 My 40 is a 3/70 model which I put a hard top from a 74 on. Since there is a difference in weatherstripping is there a difference in the heights of a windshield from the 70 to the 74? Asking because my top seems to be sitting a little higher at the windshield.
I've removed glass from FJ40 hard top sides and lift gate and from FJ60 cargo area side windows and lift gate. None of the gaskets were damaged. Just take your time and follow tips found here on MUD and elsewhere on the Internet - you may be surprised.
Here's one of my favorite videos:
AFAIK, the panels share the same dimensions.
What I have observed over the decades is that the windshield alignment has more to do with the age and overall use of the vehicle. Specifically, people tend to forget that the A pillar, the dashboard, firewall, cowl and windshield are all ‘floating’ weight, not supported by body mounts. Given time and use, the unsupported weight pulls the cowl slowly forward...and down.
Doesn't the red panel look like old for the flat glass and new for the curved corner glass? Flat glass is broken so would replace it with the later style glass and weatherstripping. Glass size is different for the different weatherstripping. Simplest way to get a matched set. :meh:
BTW, those header bars for over the rear hatch are sought after. The hinges even more so.
The dimensions of the newer ambulance door header bars are also the same... if you ever need parts (although there is a striker in the middle).
The Red panel has the early lockstrip style gasket but is using a self locking seal ( acceptable as a replacement the lock attached instead of being seperate) and the smaller glass, of which the replacement is laminated Safety Glass. The Green panel is a later style and has the offset gasket and larger glass that is tempered. Either will work for filling a hole, just depends on your preference.
Here is a good read we did a little over 9 years ago.
Excellent info, thanks to all! My rubber seems to still be soft & pliable, not dry rotted, so if I can save it, I will. I’ll remove the cracked window in one piece and have it copied at a shop. I really want to remove all the glass to properly restore these parts. I’m even going to restore that rusty green header, wish me luck!
It almost looks like the weatherstripping on the red one is in backwards?
The lip the weatherstripping fits into is flush with the inside panel. If the weatherstripping was backwards the glass would be further inside the panel. Until last spring I had hard top sides just sitting outside. Because it seems they are not worth more than scrap metal I've now stored them away.
Still stand by the easiest thing to do is replace the red side glass and weatherstripping from a 7/70+ hard top. That everything would be a matched set.
Do you have a picture of the glass in the hatch? The glass/weatherstripping changed in the hatch at the same time.
Red hatch has the older glass and green has the newer. Looks like the corner glass got broken on the red top and replaced with newer glass/weatherstripping. Since think since you have to replace the side glass on the red one anyway just use newer glass/weatherstripping. Then use the green hatch and everything will match.
