Just came in, too dark to continue. Yes, I found Coolerman's list of schematics last night, really appreciate those being there, thank you. It does have factory air and incredibly it works, blows cold air immediately. For the record, I wouldn't use wire nuts on a vehicle, those are all courtesy of the PO. I like the heat shrinkable connectors, haven't tried the ones with solder in them yet. The Sherco brand is my favorite, made in USA and good online pricing. No question solder and heat shrink is also tried and true, I'm still in teardown mode trying to figure out what was done before taking the path to redemptive repair.
We love the responses, my wife and I both had a good laugh. Yes, the clear plastic tubing is the fuel line and the black canister the filter. Just laying there unsecured. The hose section on the alternator with the brass elbow is the coolant circuit for the oil cooler, there's a pipe nipple coming out of the top to connect the loop. The wire reinforced line runs to a temp gauge in the cab. I guess someone thought this was the best way to install it. In the process they undid the fixed metal section and wire tied it to the air cleaner. The white plastic part behind the gate valve is a generic cable actuated valve connected to the pull cable in the cab, apparently that was the first attempt at a fix.
I was going to ask if we're shamed yet but it appears we may have qualified. Just in case, here are a few more images. Note the 3 switches, 2 hanging and 1 fixed, near the base of the steering column. Don't have a clue what they're for, nothing happens when toggled, key on or off. You gotta love the custom jump seat, the canteen makes it. Then there's the receiver hitch mounted 12V winch actuated lift platform. Where's the receiver you ask? It's in the bed secured by a 1 inch bolt punched right through the metal. But it does have a reinforcing plate underneath so I guess that makes it OK. The driver's side of the engine bay looks better than it is, most of the emissions vacuum lines are cracked or fall off their connections. Underneath there are more loose wires. It's a shame the way the body been's cut up, it's remarkably solid. Even the floors and rockers have no more than minimal surface rust.
Thanks for the comments, we look forward to reading them.
