What did you do with your truck this week?
Man I love that gx. On more than 1 occasion I have wished I got one of those instead of this 4 door jk.
Thanks, I LOVE it! I got 14mpg this last tank (city) which was a nice surprise.
I am putting new pads, swapping PS axle for new (spare I bought of Rick is clicking), and some new heavier duty tie rods (mine are made of ginger bread due to the length) this month.
Should be ready for GSMTR!
62
Started cleaning up and de smogging the motor for the 62
Hooked the heater back up after 4 years. Getting ready for doors. I'm excited to have doors and heat. Also installed door defrosters I had.
Don't know why winter is almost over.
That's the valve cover that has been repainted, just sitting on some tires
Decided to drill and plug the holes for the flare brackets since its been five years since I removed them for paint :D
Yes. Dorkel.
Lowest possible intrinsic value of any mod to be performed on any cruiser.
And yet I am doing it.
On the up side, I did get this all out in one piece. It is yours Marshall.
So why the giant gaping hole? OEM?
Just curious. Only had to drill the 3 1/2" hole for the safari is why I ask.
So why the giant gaping hole? OEM? Just curious. Only had to drill the 3 1/2" hole for the safari is why I ask.
Yep. OEM. Otherwise I would have probably waited a few more years to install one. It is a rather curious setup but I'm a sucker for OEM and JDM junk.
dont bet on it... I have the same set up and it leaked from day one trying to get it to bolt up to the stock down pipes... you may have to cut a crease in the down pipe and weld it to get a nice flat mating surface...
PHH in the 80,
brake pads going on in about 20 min
flush and filled the 80
pulled the console/shifters/shifter surround.. out of the 80 to see why it won't set fully into L,, its not the shifter or linkage, so I will probably crack the case open Sunday.., pull the VC while I am in there, if it is locked up.
installed $15 Hazard switch for CDL, just need new sticker
did the 7 pin mod, broke the housing, so glue had to set overnight...
